Broken door bolts.
Old Feb 1, 2021 | 05:05 PM
49F1Ken's Avatar
49F1Ken
Broken door bolts.
I was trying to remove the doors on my '68' F100, and accidentally broke off one bolt on each door. Has this ever happened to any of you?
If it did, what did you do? Any tips would be appreciated.
Old Feb 1, 2021 | 06:21 PM
1browski's Avatar
1browski
I had one bolt brake on my 72. It was the lower hinge on passenger side and it was the third bolt that is inside the door jamb. I ended up having to drill it out close to the threads and eventually getting it to come out. Started with small drill bit and worked my way up. I could access both sides of because my fender was off.
Old Feb 1, 2021 | 06:42 PM
49F1Ken's Avatar
49F1Ken
Thanks for the tip.
Old Feb 1, 2021 | 06:48 PM
cbrown9064's Avatar
cbrown9064
I broke one in the center lower also. Had fender off so grabbed it with vice grips and twisted it out from the backside...
justinking060310
1997 - 2003 F150
Mar 31, 2015 09:18 AM
evil_motors
Oct 25, 2012 09:40 PM
27 Tall T
Mar 25, 2008 07:21 PM
erinaldi
Nov 11, 2007 06:52 PM
volleyball33
Paint & Bodywork
Apr 5, 2002 06:09 AM
