55 Door keeps sagging
Old Nov 9, 2007 | 03:25 PM
erinaldi's Avatar
erinaldi
Question 55 Door keeps sagging
Hey Guys (& Gals) - my driver's side door won't stay in place. The last time I had it set by a local body shop and it worked it's way down after about a year- about a 1/4 inch. Kinda breezy near the top. I checked the manual, Ford had a special alignment jig back then. Ideas? Suggestions?
Old Nov 9, 2007 | 03:34 PM
Randy Jack's Avatar
Randy Jack
The only way I can figure that a door can "keep sagging" is either that the hinge bolts aren't tightened sufficiently (either in door or jamb), OR the jamb socket for the hinge is rotted out. Check to see where the problem could be, then reset it.
Start resetting the door by tightening the bolts between hinge and jamb. Don't miss the bolts down inside the hinge pocket.
Resetting the door is easiest with the help of a buddy. Loosen the door hinge attach bolts under the door access covers (upper and lower) and jockey the door until you like the position and the gaps around the door are as even as possible, then have the buddy inside tighten the door hinge bolts. You can repeat this process until it is as good as it will get.
Old Nov 11, 2007 | 10:31 AM
erinaldi's Avatar
erinaldi
Thank you! You got me thinking. What I did do was loosen all 12 bolts, placed a jack under the door close to the hinge, raised it, tightened the 6 bolts on the frame. Then I closed the door and used the latch to hold it in place while I tightened the 6 on the door. Worked! (So far). Thanks again.
Old Nov 11, 2007 | 11:00 AM
AXracer's Avatar
AXracer
The doors are heavy. If it sags again it's likely the hinge pocket support has rusted or broken loose either in the door or in the door frame. Also make sure your striker is adjusted properly so it isn't pulling the door down.
Old Nov 11, 2007 | 11:32 AM
erinaldi's Avatar
erinaldi
Thanks. The striker looks as if it could be moved up a bit. Has some funky bolt heads. Needs a special tool. Didn't find it at Mid-fifty or LMC. I may have to visit my local body shop for this one.
Old Nov 11, 2007 | 06:31 PM
abe's Avatar
abe
if you have the same bolts I have a real big flat screwdriver fits in the head and catches the head and tightens it .
Old Nov 11, 2007 | 06:52 PM
Brian_B's Avatar
Brian_B
Do you guys put any thread locker on them when you aligh them? Just asking since this thread is here and someday I will have to remove and re-install mine.
