Steering issues.
Old Jan 31, 2021 | 12:13 PM
David Fehir's Avatar
David Fehir
Steering issues.
Hey guy's my dad just bought a 2000 7.3 with a 6 inch lift and there is quite a bit of play in the steering to the point where the truck is a bit challenging to control going down the highway. It has steering stabilizers so I'm not sure what the problem could be. Bad stabilizers? Bad steering box? Or something else? Truck has roughly 250,000 miles on it. Any advice would be greatly appreciated. Thanks
Old Jan 31, 2021 | 09:39 PM
JeepGuy93's Avatar
JeepGuy93
Give the front a "shake down".
Jack up one wheel, grab it at 6 and 12, shake it back and forth. Repeat at 9 and 3. Then stick a pry bar underneath the tire and lift it up.
Then jack up the whole front end and put it on jack stands. Shake it down again (this will check the drag link ends and steering box).
If you feel play, look at where it is. Check the ball joints (upper and lower), tie rod ends, drag link ends, wheel bearing, and steering box.
Old Feb 1, 2021 | 10:57 AM
Paul_R7.3's Avatar
Paul_R7.3
By 250,000 miles a lot of us have gone thru 2 sets of ball joints. Every other joint in the steering linkage is also suspect by now.
Old Feb 2, 2021 | 12:16 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Great ideas above. Also (engine off, truck on the ground) lay where you can observe the whole front suspension. Have a helper swing the steering wheel back and forth. Look for any slack at any of the joints. The slack could be anywhere. Take your time to see it all.
Also if all looks tight but the wheel turns before any of the steering linkage moves that would be a loose steering gear box. It can be adjusted tighter, we can walk you thru that.
William gagen
13
Dec 10, 2019 05:32 AM
Mattb60
Dec 3, 2012 09:51 PM
parkland
Jul 14, 2011 03:18 AM
