Buying plow problems
Old Feb 11, 2021 | 05:39 PM
  #31
systems's Avatar
systems
I have a cheap personal plow on my EB and it's fine. Snowsport HD, look them up on youtube if you aren't familiar, they work great.
Old Feb 12, 2021 | 07:49 PM
  #32
JJF20's Avatar
JJF20
I’ve plowed so much snow, I’m in the thousands of hours... and that’s just in a grader. I have an opinion on this.
Plows are on just about everything you can imagine up here, Lada, jeep, truck, car, SUV, ATV, tractor, bulldozer, heavy equipment of all types... 1/2 ton, 3/4, 1 ton, no ton.
New half tons usually are not the best plow trucks, the sales person should know that as well imho, (the salesman should be helping you buy what you need) Assuming you told them your intentions to put a plow on it. I’m assuming you bought it from a Ford dealer?
One of the issues with a half ton, any make, is alot of new ones have crumple zones built into the frame and should not be used, with out risking significant damage. I have no idea if yours does or not.
That said, a lot of half tons here do the job, they get pretty beat though. I do know you can buy light weight plows for 1/2 tons, or jeeps or anything light weight. An 800# HD plow would not be good for it.
As far as EB overheating, I haven’t a clue. A lot of trucks, gas or diesel will over heat with the plow up driving or plowing on a warm winter day with heavy wet snow. Droping the plow when on the highway a few inches makes a huge difference. They all heat up in my experience. Especially the transmission. God forbid you’re doing in it a standard... those are a pain and the clutches are usually slipped all day long...
Plow trucks are usually pretty beat up, the weight out front at that arm, beat the crap out of the entire front end. Transmissions usually don’t last either.
I would agree a 3/4 ton is better, or one ton or bigger. Everything about them is built better for that job, frame, engine, tranmission, front end, you name it. Even then most put on helper or heavier front springs.
Personally, I wouldn’t want a half ton plow truck, it’s just too light weight. But, that said, if that’s what I had, I’d put a light one on it and go plow my personal driveway and never think twice about it.
Just know, no matter what you put it on, it’s going to be hard on it and wear it out one way or another.
Hope this helps,
Old Mar 21, 2021 | 08:07 AM
  #33
brokenleg's Avatar
brokenleg
Originally Posted by JKBrad
You will likely never find a used F150 with the snow plow prep package. You’re better off trading for an F250.
I just did, I found an F150 with the snow plow prep package, I own it
Old Mar 21, 2021 | 09:42 PM
  #34
JKBrad's Avatar
JKBrad
Whoa! That’s a rare truck. Congrats!
Old Mar 21, 2021 | 10:11 PM
  #35
smokewagun's Avatar
smokewagun
My last 2018 5.0L that burned oil had the package and the funky little switch to shut off the heated seats and other accessories. Why would Anyone need heated seats while plowing in winter? Stuuuuupiiiiid!
Old Mar 21, 2021 | 11:10 PM
  #36
brokenleg's Avatar
brokenleg
thanks. But the snow plow package just happened to be on this truck. Just means both of my Fords are snow plow prep trucks..
Old Mar 22, 2021 | 08:51 AM
  #37
TC63's Avatar
TC63
Sarcasm ???
Old Mar 22, 2021 | 10:05 AM
  #38
ford390gashog's Avatar
ford390gashog
Originally Posted by TC63
Sarcasm ???
Definitely not.
Old Mar 22, 2021 | 05:15 PM
  #39
TC63's Avatar
TC63
Originally Posted by ford390gashog
Definitely not.
OK sorry, i misunderstood
FXM
General Automotive Discussion
Jan 30, 2021 02:42 PM
sailorman3
Apr 27, 2020 08:46 PM
unhcp
Oct 16, 2011 12:06 PM
cykoticford
Mar 7, 2008 08:31 PM
technoman26
Aug 8, 2007 07:31 AM
