Engine Tap
Old Jan 26, 2021 | 02:47 PM
rekrap95's Avatar
rekrap95
Engine Tap
2007 F-150 5.4L 194k miles
The noise started about 3 years ago, when the engine was COLD but once the truck ran for 10-15 seconds, the noise settled down and stopped. A few days ago, it stopped settling down and is now noticeable even while driving.
I stuck a screwdriver to the valve-cover and tried to take a listen and with my novice mechanic ear Im pretty sure its coming from cylinder 7 or 8.
Ill add a video I took from my phone. If anyone has experienced this themselves or has any ideas, please let me know Id be grateful.
File Type: mov
Old Jan 26, 2021 | 03:04 PM
rekrap95's Avatar
rekrap95
Video of Noise
Original video was too big. Here is a short clip, you can hear the tapping
File Type: mov
Old Jan 26, 2021 | 05:13 PM
hobohilton's Avatar
hobohilton
Get some Marvel Mystery oil and add it to the crank case. Continue to drive it.
Hobo
Old Jan 26, 2021 | 05:43 PM
rekrap95's Avatar
rekrap95
I just did an oil change today about 300 miles prematurely and substituted the MMO for the 7th quart because I had read some good stuff through google about. Hopefully it helps, thanks for the reply.
Old Jan 28, 2021 | 02:02 AM
3Prcntr's Avatar
3Prcntr
It's worse because it's been driven on for 3 years. The more you drive it, the worse it gets. Possible stuck lifter/roller/follower and top end issues not getting the oil it needs. If the cam phaser and timing are off, you run into even more serious issues. No additive will help or solve these issues. You either fix it, or run into worse issues down the road.
Old Jan 28, 2021 | 09:03 AM
redfishtd's Avatar
redfishtd
My engine threw no 8 roller out on one of the intake valves . The drivers side valve cover is easy to get off , you can pop rollers out .The roller bearings are probably shot on at least one . I would change them all on no 7 and 8 ,if they damage cam when thrown that will be a bummer.
^^^^^ I believe he's right no liquid is going to repair it now. MMO is a preventive not a fix . Me I would do an engine flush just before pulling it open just to make it easier to see stuff .
Old Jan 28, 2021 | 09:20 AM
WWR's Avatar
WWR
This is worth the watch, or if in a hurry watch from :45 to 1:45
Old Feb 1, 2021 | 02:58 PM
46fordtruck's Avatar
46fordtruck
I had the same thing, stuck followers, scored the cam. I tried MMO in the beginning, but it's not gonna do any good. The more you run it the more you are grinding the parts down, bits of metal getting into the oil. The parts aren't too expensive, it's the labor that's the pain.
Snakez31
May 22, 2018 01:53 PM
jocasio
Nov 2, 2012 03:05 PM
case_7010
6.4L Power Stroke Diesel
Nov 10, 2008 07:41 PM
hms365
3.0L V6
Nov 13, 2003 12:58 AM
JnJ
1983 - 2012 Ranger & B-Series
Aug 3, 2003 11:21 PM
