4.6 replacing a 5.4?
Old Feb 4, 2021 | 02:56 PM
skahide's Avatar
skahide
I know it isnt a very desirable swap.
My dad has a 2002 2wd with a FRESHLY rebuilt 4.6 motor. The transmission is now busted, and the rest of the truck is in rough shape (farm truck that is surprised it holds together).
He has as an opportunity to purchase a 2005 4wd with a busted 5.4 (but everything else is great) for cheap.
Is it possible to simply pull the 5.4 and drop in the 4.6? I didn't see any write-ups but from what I've read......it should be fine.
Old Feb 4, 2021 | 04:00 PM
Lime1GT's Avatar
Lime1GT
Your working with two different series of trucks. The engine may bolt up but it's the electronics {computers, wiring harness, etc} and matching transmissions that need to be thought about. You'll definitely have to do a lot of research unless someone here has done it before.
Old Feb 4, 2021 | 04:15 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Lots of little bits have to change. The intake and throttle, for starters, as the new body ‘04-on use electronic throttle versus cable.
I’d find some other use for that 4.6 and get one that came from an ‘05 (or as close a year as possible) hopefully with all the goods in place to where you should be able to pop the computer in place and plug the harnesses in and go.
Use a 4.6 torque converter as well.
Old Feb 4, 2021 | 04:20 PM
skahide's Avatar
skahide
Well that helps a lot. Thank you VERY much for the info. Ill definitely use the 4.6 for something else.
Curious: so if I do swap the 4.6 into a f150 I just need to stay in the same generation?
Old Feb 4, 2021 | 06:04 PM
redfishtd's Avatar
redfishtd
It would be easier to buy a reman 5.4 for $3200 than do the 4.6 .. Plus you would have a warranty .
bass-n-fire
1997 - 2003 F150
Feb 3, 2020 08:11 AM
jdsgtball
Engine Swaps
Nov 22, 2011 08:21 PM
mmri101
Sep 4, 2009 08:46 PM
fordmandan
1997 - 2003 F150
Oct 4, 2001 11:08 AM
