Sponsored by: Real Truck
Hard shifitng
Old Jan 25, 2021 | 10:52 PM
Angel1973's Avatar
Angel1973
Hard shifitng
1999 F350 shifts hard and then acts like you throw it in neutral and revs up then slams back into gear. What causes this?Only one code PO 500 and I replaced the VSS still same thing
Old Jan 26, 2021 | 08:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first thing to do is to fix the problem causing the P0500. Since a new sensor didn't fix it, I suspect there is a problem with the wiring between the PCM and the VSS. You need to check each of the two wires for continuity, short to power, and short to ground.
Turpdawg23
Jan 31, 2021 04:46 AM
Angel1973
Jan 19, 2021 09:16 PM
NICKSAN
May 2, 2017 10:04 PM
frankiethethumper
Oct 8, 2014 09:32 AM
frankiethethumper
Oct 7, 2012 06:09 PM
