Dome light not working
Old Jan 25, 2021 | 10:18 PM
agtech's Avatar
agtech
Wondering if anyone has a wiring diagram for my 1999 F350 crew cab for the dome light circuit. It wont come on with the light or door switches. I can make them come on by grounding the #1 relay in the fuse box. Checked the light switch and it seemed to be working properly, sending a ground signal out when moved to the 'dome on' position. I have searched threads for 2 nights and cant find anything. Thanks
Old Jan 26, 2021 | 06:22 AM
udsuth78's Avatar
udsuth78
https://www.ford-trucks.com/forums/1...t-problem.html
Here's a thread that has a couple diagram.
Old Jan 26, 2021 | 09:08 AM
agtech's Avatar
agtech
Thanks for the help, it looks like I have a faulty GEM. I'll make sure i'm getting signal into it and let you know what turns up.
Old Jan 26, 2021 | 09:24 AM
udsuth78's Avatar
udsuth78
Good luck. Btw that was found with a Google search for "99 super duty dome light wiring diagram" for future reference and those playing at home.
Old Jan 26, 2021 | 03:58 PM
Gamsler's Avatar
Gamsler
4wd Low
Courtesy Dome light not working
Had the same problem with my 2001 250 SD, did the research, was going to replace my GEM also but decided to replace the top white relay for $6.00...Bingo!! Works every time, all the time..
TILLY
1997 - 2003 F150
22
Jul 1, 2023 03:35 PM
extropic
Nov 26, 2018 02:42 AM
Dan Drover
Jul 30, 2014 04:41 PM
79FordBlake
1978 - 1996 Big Bronco
Oct 15, 2008 05:34 PM
is300wrx
2004 - 2008 F150
Dec 25, 2005 09:43 AM
