Sponsored by: Auxito
outside cab light stays on
Old Feb 29, 2004 | 06:26 PM
TILLY's Avatar
TILLY
I have a 1997 f-150 with a problem. The outside cab light won't
turn off. When I open either door and shut them, that light will stay on for hours. If I disconnect that fuse what else will I disconnect?
HELP
Old Feb 29, 2004 | 06:58 PM
Beast12's Avatar
Beast12
You may want to try this forum: https://www.ford-trucks.com/forums/f...?s=&forumid=25
Also, if you interior light is on doesn't your outside light come on too? Try turning your dome light off with your switch. Since it is day, you probably don't notice it on. Try it out.
-Matt
Old Feb 29, 2004 | 10:04 PM
NASCARTruckDude's Avatar
NASCARTruckDude
Does your dome light stay on also?
Old Feb 29, 2004 | 10:15 PM
MJEmerson's Avatar
MJEmerson
try lubing the doors with a spray lube...and check the switch...I am pretty sure that the dome and the cargo light work off the same wiring, and switchs. I dont think that they can operate independently of each other.
Old Mar 1, 2004 | 12:39 AM
archer1's Avatar
archer1
Lift the door handle and spray some wd40 into the slots inside the handle, do this on both doors and work the latches and this problem will go away quick.
Old Mar 1, 2004 | 05:06 AM
TILLY's Avatar
TILLY
The inside dome light and the outside light are both on. My
13 year old boy unscrewed the bulbs to that!!! I will try the WD.
I hope it works.
Thanks all!!
Old Mar 8, 2004 | 05:04 PM
Firefighter 1406's Avatar
Firefighter 1406
If the wd dont work, you will have to replace the switches. they run 70 dollars each and are quite labor intensive to change but it worth it because the problem it very annoying.
Old Mar 8, 2004 | 07:05 PM
thomald's Avatar
thomald
I don't know about the F150's but my 250 did the same thing. The drivers door switch was the problem. The switch cost me $7.00 and took all of ten minutes to fix. If you unplug the fuse, your speedometer will not work and if you have the electronic transmission, it won't shift either. There are many things hooked up to that fuse and one of them is the sensor for the speedo. That was my experience on my 94 model.
Old Mar 8, 2004 | 07:17 PM
MJEmerson's Avatar
MJEmerson
hey Tilly...did the wd work?
I dont know if disconnecting that fuse will shut down the speed o and tranny...that seems like a major engineering fault if its true. I think all of the interior lights and bed light are wired together and should have an independent fuse and switch, but I may be wrong. the manual will tell you for sure though.
Old Mar 8, 2004 | 07:41 PM
thomald's Avatar
thomald
My book only goes to 96 but all is the same on all F-series units including the Bronco. 97 could have been different but I promise, you'd be surprised what they wire together. On those F-series trucks the speedo sensor is in the rear axle housing. It drives the speedo and the speedo drives the transmission, after a fashion, and they all go through the same electrical fuse. Good luck!
Old Mar 8, 2004 | 08:01 PM
MJEmerson's Avatar
MJEmerson
wow....I am surprised, so basically you could blow a fuse because of a short in a light socket, and be stranded. thats is rediculous. good information to know...i got a lot of friends with older fords
Old Mar 8, 2004 | 08:21 PM
TILLY's Avatar
TILLY
The WD didn't work so I tried TRI-FLOW That did the trick-- A teflon lubricant. Good Stuff!! Thanks for all your replys
Tilly
Old Mar 8, 2004 | 10:10 PM
MJEmerson's Avatar
MJEmerson
glad it worked out...it seems like 90 percent of the time its a lube issue.
Old Mar 9, 2004 | 06:12 AM
Beast12's Avatar
Beast12
-Matt
P.S. I didn't say one word........except these ones!
Old Mar 9, 2004 | 07:49 AM
leroys4wd's Avatar
leroys4wd
Ford did some funny wiring, boy. In my '96 Explorer if you pulled the fuse for the interior lights (I used to sleep in it with the hatch open) the four wheel drive wouldn't work.
