Hello all, I am still having difficulty locating the Knock Sensor on a 5.0 Ltr 1988 F150. After being advised that it is on the upper inlet manifold, I had a good look around. But was only able to find what looked like a vacuum port with many vacuum hoses coming from it. Nothing like what I would expect a knock sensor to look like.
[font size="1" color="#FF0000"]LAST EDITED ON 02-Nov-00 AT 08:39 PM (EST)[/font][p]It is located on the rear part of the engine block behind the intake manifold, right in between the two bellhousing bolts. Email me your address and I will send you a picture from All Data.
Send me your address to deleontow(No Email Addresses In Posts!)
Is it possible to retrofit a knock sensor into an older style block?
The reason I ask, is that I am rebuilding a motor for my truck and the block is from an '84 Lincoln.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
