fuel filler difficulties
Old Oct 26, 2003 | 12:34 AM
drunkenmonk's Avatar
drunkenmonk
has anyone ever had this problem?
when I put gas in my 74 F250 , I have to go super slow, or else gas backs up the pipe and spills out
anyone have any input?
Old Oct 26, 2003 | 12:35 AM
Mil1ion's Avatar
Mil1ion
Yes, It is talked about ALL The time around here.
You just need a pocketfull of patience or convert it to a 78/79 Bed & tanks
Old Oct 26, 2003 | 12:37 AM
LxMan1's Avatar
LxMan1
Sounds like you have some blockage in the filler vent. It is the smaller hose the runs along the large filler hose. Check to see if it is kinked or something.
You can remove it and see if it is clogged, also check the nipples that it hookes to for blockage.
Jimmy
Old Oct 26, 2003 | 12:45 AM
drunkenmonk
sounds reasonable
both tanks do it, looked at them briefly, and it looked like the vent hose on the reserve had split open in one part
it's not aproblem I can't live with, just wondered if I was missing something
thanks for the help
Old Oct 26, 2003 | 12:47 AM
Dan Q's Avatar
Dan Q
Jimmy
That does it. And if you are crazy enough to remove the hose (like say, when installing a body lift) you will have this problem until you put the small hose back in. Trust me... I dealt with it until someone told me and I replaced it.
On the money lxman1.
Dan Q
Old Nov 10, 2003 | 12:15 AM
chevey hater77's Avatar
chevey hater77
my truck had the same problem it turnes out that when i put
on my new bed i pinched the hose. look for this or maby your
vent hose is pinched.
77 forddddd
Jan 22, 2012 04:59 PM
95 Lowbuck
May 5, 2008 10:54 AM
jlstorm
General Automotive Discussion
Dec 22, 2005 08:42 PM
Mike Cook
Bronco II
May 12, 2004 12:58 PM
james1123
Aug 11, 2003 11:01 AM
