Stalling in Reverse and Drive
Old Jan 24, 2021 | 07:22 PM
mr jits's Avatar
mr jits
Hi all, my daughter's '89 f250 (4wd, 302) is stalling when in reverse and in drive when coming to a stop (it's not common in drive, but easily 8/10 when shifting into reverse.
Background on the truck: my daughter bought it with her own money (17 yo) about six months ago. It's never run particularly well. We did the basic tune-up upon purchase; plugs, wires, filters, oil, coolant flush. And it's had issues when shifting into reverse since purchase. Truck has 226k, 110k on a full rebuild done fifteen years ago. Daughter is the second owner.
I've replaced all three fuel pumps, fuel filter, IAC, TPS, and MAP. The truck had codes for TPS and EGR (I'll be doing an EGR delete) which I addressed.
I'm at a loss at this point. Ideas and suggestions are appreciated
Old Jan 25, 2021 | 09:30 AM
jas88's Avatar
jas88
What trans do you have?
Old Jan 25, 2021 | 10:56 AM
mr jits's Avatar
mr jits
E40D I believe.
Old Jan 25, 2021 | 04:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by mr jits
E40D I believe.
Not in an '89 with a 302. It wasn't available.
What trans code is on the data tag in the driver's door jamb?
Old Jan 26, 2021 | 12:30 AM
mr jits's Avatar
mr jits
Transmission code "T". AOD?
Old Jan 26, 2021 | 11:20 AM
JPIECHOC50's Avatar
JPIECHOC50
The first thing I would do is check the tranny fluid level when the truck is warmed up
Old Jan 26, 2021 | 12:23 PM
ryan73ford's Avatar
ryan73ford
Take a look at the trucks catalytic converter on the exhaust if it has one, I had a truck at my old job with very similar symptoms and miles, just turned out that the Cat was clogged up.
Old Jan 26, 2021 | 07:29 PM
Mark Kovalsky
Yes, that's an AOD.
Old Feb 3, 2021 | 01:17 PM
mr jits's Avatar
mr jits
Well, still looking for suggestions.
High idle (~1000rpm), slight stutter on acceleration, stalling sometimes in reverse.
Old Feb 3, 2021 | 01:37 PM
Encho's Avatar
Encho
The Southernmost Mod
As usual, check for codes, clean the IAC and the throttle body. I also suggest pulling out a couple of spark plugs if you haven't replaced them in a while, also replace the fuel filter if it's been there for a while (70k miles tops).
Old Feb 3, 2021 | 02:45 PM
mr jits's Avatar
mr jits
I cleaned the throttle body when I did the TPS. IAC is new. Plugs and wires are new. Fuel filter, and all fuel pumps are new, as well as the fuel pressure regulator.
Sold the truck today to get the daughter into something reliable (Toyota). It's just crazy that there are so many people with related issues, but there's never a definitive answer to the problem. Just a blackhole of probabilities.
evan1242
Aug 7, 2015 02:43 PM
Rev440x
2004 - 2008 F150
Nov 11, 2005 12:47 PM
8996EBBroncos
1978 - 1996 Big Bronco
Mar 22, 2002 12:43 PM
