Transmission problems
Old Jan 24, 2021 | 05:46 PM
Michael Allison's Avatar
Michael Allison
I’ve got a 1997 ford f 250 with a 7.3 power stroke and I’ve got a trans problem. The truck as an e4od. And when I drive with the truck empty it’s just find but when I put a trailer behind it. The trans likes to slip in 2nd and third gear. If I put the truck on the floor it will grab 3rd gear and hood but as soon as I back off it starts slipping. Wanting to know if I got trans issues or a torque converter problem
Old Jan 24, 2021 | 06:35 PM
97-psd's Avatar
97-psd
Does the overdrive light flash?
Old Jan 24, 2021 | 09:35 PM
Michael Allison
No it does not
Old Jan 25, 2021 | 10:20 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is the trans fluid black? If the trans is really slipping it will burn the trans fluid in a few miles.
The torque converter has a locking clutch. This clutch is applied and released by the PCM (Powertrain Control Module) aka, the computer. It decides when to lock it and unlock it. In second and third gears it usually has the torque converter unlocked.
Old Jan 25, 2021 | 03:23 PM
Michael Allison
The fluid looks and smells perfect which is why I jumped on here for help. But I think I’m just gonna go ahead and bite the bullet and get a billet torque converter and build the transmission
Old Jan 26, 2021 | 11:50 AM
z31freakify's Avatar
z31freakify
Check your trailer wiring you might have buggered wires specifically the brake wire allowing the TC to slip.
bruce.o
Oct 29, 2011 12:38 PM
70spoiler
Jan 30, 2010 01:38 PM
scbronco
Sep 19, 2008 05:43 PM
mikey11211
Oct 28, 2006 02:27 AM
