Jack replacement?
Old Jan 23, 2021 | 09:19 AM
Mjollnir81's Avatar
Mjollnir81
Jack replacement?
A little while back I took out my underhood jack and tried to extend it so I could clean it and grease. It was a huge PITA to extend. Has anyone been able to fit a bottle jack in it's place under the hood? The shape of the two seem comparable. I worked my original up and down quite a few times and it does extend, but I dont care for how hard it is to get to full extension without tipping over first, and that it's not entirely stable on flat ground.
Old Jan 23, 2021 | 11:26 AM
FuzzFace2's Avatar
FuzzFace2
Did you try and lube the crap out of it?
Even when new the jacks never stayed up right when you worked them.
I did lube the crap out of mine but it needs to be replaced as it jammed up and will not move any more.
I did place it back under the hood so it looks good LOL
Dave ----
Old Jan 23, 2021 | 12:09 PM
Max Capacity's Avatar
Max Capacity
I would think between a clamp from the hardware store and a little thought you should be able to come up with a combo that would work. Think outside the box.
Old Jan 23, 2021 | 02:01 PM
Kramercd's Avatar
Kramercd
You could get one in the plastic box and bolt the box to the inner fender. Wouldn't exactly look stock though. Might have to make a new bracket to match the bottle jack that bolts in the same place as the stock jack.
Old Jan 23, 2021 | 07:19 PM
Franklin2's Avatar
Franklin2
You are not going to find a bottle jack that is as compact as the stock jack, and extends the same distance as the stock jack. With a bottle jack you are going to find you need a significant block of wood to go along with it to lift the truck up. These trucks are high off the ground, especially a 4x4.
Next time you change the oil, put it in a 5 gallon bucket and sit the jack down in it and leave it for a week. Pull it out into a pan and let it drain and see if that helps it.
Old Jan 23, 2021 | 07:41 PM
Kramercd's Avatar
Kramercd
Trans fluid would do better than the motor oil.
Old Jan 23, 2021 | 10:29 PM
BigBlue2's Avatar
BigBlue2
I keep my jack operational by generous lubing with Fluid-Film. Lube it or lose it. These are great little jacks that work well.
I've even used mine as a house jack. Works perfectly.
Old Jan 23, 2021 | 10:32 PM
Kramercd's Avatar
Kramercd
I didn't have to do anything to mine. It functioned perfectly when I got the truck. Everything else was gone though.
Old Jan 24, 2021 | 11:02 PM
BigBlue2's Avatar
BigBlue2
Yeah mine has always worked great too. But lubed up with Fluid-Film it works even smoother. Also keeps the threads from rusting any more than they are now.
jdt10768
Mar 24, 2020 02:31 AM
GuitarJesus
Jun 4, 2012 07:21 AM
hummer5
Jan 4, 2011 09:49 PM
b_berkeley
1978 - 1996 Big Bronco
Feb 21, 2003 10:33 AM
mrblue01
Dec 2, 2001 08:56 AM
