Programmer that won't void warranty ????
Old Jan 22, 2021 | 12:02 PM
nickj niehaus's Avatar
nickj niehaus
4wd Low
OK Diesel brethren !!! What programmer is available (best) for my 2019 duece w/ the 6.7Dsl ??? My warranty is 100K .. i really don't want to void that... but, i need to be able to adjust my tire size (35's) vs speed, miles etc and i'd like to have something to up my HP & MPG ?? I also want as much diagnostic display as possible ? I had an Edge on my old 7.3.. but, I think there likely much improved ones out now...
Old Jan 22, 2021 | 12:25 PM
ford390gashog's Avatar
ford390gashog
The minute you alter the PCM the warranty is in question. There is no magical reset as the hard code will set. For tire size you can use forscan without touching the PCM.
Old Jan 22, 2021 | 01:00 PM
Pugga's Avatar
Pugga
Check out Banks. It’s a piggy back tuner so it doesn’t leave any trace on the ECU.
Old Jan 22, 2021 | 01:32 PM
GNR22's Avatar
GNR22
Banks Derringer. Like Pugga said, no trace on the ECU.
Old Jan 22, 2021 | 03:37 PM
ford390gashog
There most definitely will be a trace if someone is inclined and follows the warranty analysis shop guide. The TCM stores and records all the output torque values, they will show as exceeded. The guide also goes into piston spray pattern and skirt scuffing.
Old Jan 22, 2021 | 05:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Nice thought, too bad it isn't true. If you increase the power the engine produces it's going to set a code that cannot be cleared and that could be the end of the warranty.
Old Jan 22, 2021 | 05:37 PM
CJONE's Avatar
CJONE
Boost pressure, fuel pressure and output torque amoung a bunch of other things, yea as was stated it will be obvious to anyone looking. Cj
Old Jan 22, 2021 | 05:39 PM
Pugga's Avatar
Pugga
Ok, so let’s go one step further, a piggy bank tuner is not nearly as easily detected as one that overwrites like an SCT. If you have a completely catestrophic engine failure due to improper tuning and try to pass it off as warranty work, you’re going to get caught. Simply being able to unplug and remove a piggy back tuner quickly takes that out of the equation if you have minor warranty work otherwise, a dealer could get caught up on the tune and blame everything on that, even if it’s not the cause. Unplugging and removing a piggy back tuner, for standard or routine work, no one would be the wiser that it was ever there.
Even with an overwrite tune, it does not flat out void the warranty to the letter of the law. They still have to prove that the tune is what caused the warrantied part to fail. That said, that’s an uphill battle with engine parts on a tuned vehicle.
Old Jan 22, 2021 | 06:49 PM
Mark Kovalsky
That is just flat out wrong. Any good Ford tech knows how to determine if there EVER was a tune, whether it was an overwrite or a piggyback. They are 100% detectable.
Yes, that's how it is supposed to work. No, that isn't what happens in reality.
What happens is that they detect the tune and refuse to do warranty work. How are you going to force them to do warranty repairs?
Old Jan 22, 2021 | 07:07 PM
GABAR's Avatar
GABAR
Once you use an aftermarket tuner when the vehicle is still under the manufacturers warranty, that’s all a dealer will need to void your warranty and deny any claims. There will always be an electronic footprint.
Use the tuner after the manufacturers warranty has expired.
Old Jan 22, 2021 | 07:38 PM
Pugga's Avatar
Pugga
under what circumstances would a good tech even go sniffing for any trace of a piggy back? If you’re talking catastrophic failure, sure, routine stuff though, how would they determine a piggy back was ever there? If you bring in a truck for warranty and the engine is completely toast, sure, Ford is going to dig in. I’m learning something new here which would mean Gale Banks is a bold face liar with his claims.
i did say it would be an uphill battle if you get into the Magnuson-Moss act debate with a dealer.
Old Jan 22, 2021 | 10:36 PM
ml8163's Avatar
ml8163
Don’t listen to this. I have the Banks Derringer and pedal monster on my 2019 6.7. Have had to take the truck in for a check engine light due to a glow plug module needing replacement and had no issues with warranty. In full disclosure, I did uninstall both to play it safe before taking to the dealership , which takes 10 minutes tops.
Old Jan 22, 2021 | 11:04 PM
ford390gashog
Not like Mark spent decades working for Ford engineering or anything..... You do know Ford spends plenty of money investigating failures to the point they have a field checklist to void repairs. The one that covers Diesel engines is available online from the service portal and cannot be posted here but here is the one for gas engines and it can be posted.
Old Jan 23, 2021 | 04:33 AM
Lamoon78's Avatar
Lamoon78
They wont most dealers more than likely wont even look mine doesn’t.
Old Jan 23, 2021 | 07:49 AM
Rjacks258's Avatar
Rjacks258
But bro, black smoke and rollin’ coal is much cooler.
cracks me up when diesel owners wanna “up their power”. For real, how many actual owners are maxing them out? The dudes with the 24x14’s on low pro tires definitely aren’t. Stock is king.
