Programmer that won't void warranty ????
Old Jan 23, 2021 | 08:02 AM
shawnee1's Avatar
shawnee1
Originally Posted by Lamoon78
They wont most dealers more than likely wont even look mine doesn’t.
The dealer doesn't make the decision to do warranty repairs. Ford does. For minor problems (such as the previously mentioned glow plug module), Ford is not going to dig deep. For major problems (such as a blown engine or cooked turbo), Ford is going to dig deep to find the cause of the problem.
What I got out of this thread is that tunes can be detected if Ford wants to. The fact that it is not checked every time power train related warranty work is performed does not mean it can't or won't be detected. If a major failure occurs, you can be certain Ford will check. Ford will reject the warranty repair if a tune is found. Ford may reject a warranty claim even though the evidence indicates the tune was not the direct cause. Look how quick Ford refuses to cover cp4 pump failures if evidence of water is found in the system even though the pump is a known problem. You can fight the rejection in court but the cost will far exceed the repair.
Owners who run tunes take a risk. The risk may be very low but it is still a risk.
Old Jan 23, 2021 | 09:57 AM
Plethora Green's Avatar
Plethora Green
Yes there's always a risk. There's a risk when you walk out your front door everyday too doesn't mean you shouldn't do it.
I had a short block replaced on my 2013 Ecooboost after a piece of the #4 piston skirt let loose and fell to the bottom of the oil pan. All under warranty I didn't pay a dime and had been tuned. Was never even a conversation about it in the slightest.
One example, doesn't mean anything one way or the other, but food for thought.
johnzenobia
2009 - 2014 F150
52
Jun 3, 2015 03:04 PM
thegap1
Oct 30, 2008 12:16 PM
donjamer
New Hampshire Chapter
301
Aug 25, 2008 02:43 PM
snowdog79
2004 - 2008 F150
19
Apr 2, 2007 06:03 PM
erik_bishop
Nov 26, 2006 01:11 AM
