M5od r2
Old Jan 20, 2021 | 01:53 PM
Romberger's Avatar
Romberger
M5od r2
I’m in the process of getting everything I need to put a 5 speed in my bullnose but I hit a snag. The M5od i got (for free) is from a 92 and has the electric speedometer is there a way I can change that a gear driven setup so I don’t have to change anything on my truck speedometer wise
Old Feb 23, 2021 | 08:04 PM
DeskDrawer's Avatar
DeskDrawer
EDIT -- nevermind, this wont work. You're going from electronic to cable driven.
This should work:
https://www.dakotadigital.com/index....od/prd1192.htm
You'll need to configure it so there's a free app you install on your phone that allows you to configure the device and fine tune your speedometer reading. Also, if you don't have a wiring diagram, make sure you install the device close to the transmission and before the speedo signal is split (ex: one going to the ECU and the other going to the dash).
Old Feb 23, 2021 | 08:39 PM
85e150's Avatar
85e150
I think you need something like this:
https://www.speedhut.com/Speedbox.html
Post 2 looks like electronic to electronic.
MkeMike
Feb 24, 2018 12:08 PM
AceinAZ
1978 - 1996 Big Bronco
Aug 23, 2015 06:01 PM
BigBlockF350
Mar 30, 2013 04:47 PM
JetBlackBronco
Nov 19, 2005 01:56 AM
munrow
Mar 9, 2005 09:35 AM
