Speedometer Calibration
Old Feb 23, 2018 | 10:14 AM
MkeMike's Avatar
MkeMike
2018 CCSB SRW 6.7 Lariat
Getting my 4" BDS RA Lift installed and upgrading to 37's
What do you guys use to re-calibrate your speedometers?
Old Feb 23, 2018 | 10:16 AM
stewy604's Avatar
stewy604
I have that same setup on mine, I left the speedo alone. With Forscan, you can get close to 35's I believe. For me, I'm ok with the truck logging "less miles" and reading slower than actual.
Old Feb 23, 2018 | 10:29 AM
Tricon's Avatar
Tricon
You can use FORscan to change your tire size, 35's work fine, 37's will throw a CEL. Only other option is a Hypertech Speedo calibrator. You have to remove the dash (IPC) and install it. Once its installed you're good to go.
Old Feb 23, 2018 | 10:43 AM
MDK123's Avatar
MDK123
Left mine alone and estimate MPH. I just add about 10% to current speed.
Old Feb 23, 2018 | 01:13 PM
POLSKI76's Avatar
POLSKI76
I did the same lift too, Went the DSC coil over and the ride quality is amazing compared to stock. Like mentioned above I have decided to just leave it, 10% will keep you safe.
Old Feb 23, 2018 | 07:40 PM
EdwardC's Avatar
EdwardC
Same lift and tire size for me as well and I also left the Speedo alone.
Old Feb 24, 2018 | 11:40 AM
Slavoise's Avatar
Slavoise
I'm running 37s and bought this: Hypertech
Works great and super easy to install.
Old Feb 24, 2018 | 12:08 PM
MkeMike's Avatar
MkeMike
Thanks everyone!
Rumble phish
2004 - 2008 F150
Jun 5, 2019 04:12 PM
metru
Nov 8, 2017 09:26 PM
GOVTMOD
Jun 13, 2012 08:57 AM
tholt34
Apr 30, 2007 12:29 AM
Greg250
Feb 20, 2004 03:19 PM
