1978 - 1996 Big Bronco
speedometer adjustment?????
Old Nov 17, 2005 | 07:19 PM
JetBlackBronco's Avatar
JetBlackBronco
Question speedometer adjustment?????
well i guess i need to adjust my speedometer in my 91. i got a fast driving award last week, and was informed by the officer that i was goin 64mph, when his radar hit me, i looked and my speedo said about 57. i checked it with my GPS, and well at 57, im goin 61. whatever the case i need to adjust it. does anyone know how to do this...if its possible?? any help is appreiciated
Old Nov 17, 2005 | 08:03 PM
cjbronco's Avatar
cjbronco
IM not sure what years started to use computer controlled speedo readins, might be 91' but I kno on my 82' i have to replace the speedo gear thats at the top of the t-case. Theres some formula to calculate it, I have it in my JBG mag, but thats in the truck right now. Good luck man
Old Nov 18, 2005 | 02:03 AM
greystreak92's Avatar
greystreak92
Ford didn't start using the PSOM (Programmable Speedomoter/Odometer Module) until '92. You will have to change the output gearing to the cable. Out fo curiosity, what has been changed on your truck that would put the speedometer +4 mph off. Larger-than-stock tires or something else?
Old Nov 18, 2005 | 07:09 AM
cjbronco's Avatar
cjbronco
mine consists of 3.70 and 33's
Old Nov 18, 2005 | 09:24 AM
JetBlackBronco
just over sized tires...32x11.50s, prolly next summer ill be getting one size smaller tire, 31x10.50. but thats the only change, still have stock gears 3.55:1
Old Nov 19, 2005 | 01:56 AM
TakeEm's Avatar
TakeEm
That'll do it.
I'm running 33's and 3.55 gearing. MPH = I don't know - my speedo is broke. I'm guessing I'm about 10 mph + or - a few over the stock set up. At 1500 rpm's I'm running around 70.
