ring gap
Old Jan 20, 2021 | 10:04 AM
dantimdad's Avatar
dantimdad
ring gap
I am getting ready to assemble my 460 std bore. I have mahle moly rings going on KB hypereutectic pistons with valve relief to up the compression some. I have read that .0065 X 4.360 is the ring gap I want for NA with no nitrous. I may want to run nitrous in the future (just a small shot for a grin once in a while) Should I go with the 0080 X 4.360 or not? Maybe somewhere in between?
Other mods to the engine are:
Weiand intake
Street demon carb
Flotech headers
Lunati Vudoo cam kit (lifters, springs, timing set, cam)
HEI distributor
Thanks for the help.
Old Jan 20, 2021 | 11:10 AM
dantimdad's Avatar
dantimdad
I finally got ahold of someone from UEM.
The answer is go with 0080 mulitplier on the first ring even if I am not running nitrous right now since it's in a truck that may tow a trailer once in a while.
.0040 multiplier on the second ring. There is no difference on this one nitrous or not.
Interestingly, he said you can yank to the top of a piston clean off if you don't allow enough ring gap so err on the side of caution.
Old Jan 20, 2021 | 11:27 AM
Tedster9's Avatar
Tedster9
Originally Posted by dantimdad
Interestingly, he said you can yank the top of a piston clean off if you don't allow enough ring gap ...
I hate it when that happens!
Old Jan 20, 2021 | 11:30 AM
dantimdad's Avatar
dantimdad
LOL! Me too!
Old Jan 25, 2021 | 11:50 AM
DaveMcLain's Avatar
DaveMcLain
And that happens a lot with a KB hyper piston if the ring end gap recommendations are not followed.
A story on end gaps: A couple of years ago I rebuilt a 350 Chevy engine for a guy who wanted to run nitrous. I followed the instructions that came with the rings(Mahle) and put the engine together. After it was assembled I ran it on my dyno and the customer came down to help with the testing and have some fun. He noticed right away that I didn't have any breather in the valve cover yet no oil came out and he really couldn't see any significant blow by. He said, "I thought I told you to gap the rings for nitrous did you forget"? I told him I did and he was amazed at how little it leaked under load. In other words it doesn't hurt much to have a little extra end gap. That engine made 600 horsepower at 7000rpm and he ran a 200 shot most of the time.
Old Jan 25, 2021 | 12:05 PM
dantimdad's Avatar
dantimdad
Thanks for the info.
It backs up my decision to go bigger.
william16339
Sep 12, 2016 09:10 PM
BuckTruck
Feb 11, 2016 10:31 AM
saleen065
Jul 7, 2008 06:49 PM
MACK2052
Mar 23, 2007 03:04 AM
theguy_88
Feb 23, 2006 12:06 PM
