General Automotive Discussion
fuel issues
Old Jan 18, 2021 | 04:35 PM
nealcphillip's Avatar
nealcphillip
Talking fuel issues
I have a 1987 Ford R150 that starts and dies so i replaced all three fuel pumps, fuel pump relay, filter and all started the truck it ran normal for about 20 minutes died, went to start it it would not start, ley it sit overnight, the next day it started and died after a few seconds, what am i missing, noticed that there is not fuel to the rail after it dies, any help with this issue would be helpful
Old Jan 18, 2021 | 04:40 PM
hobohilton's Avatar
hobohilton
The Fire Triangle = oxygen, fuel, ignition.
Determine which one is going away before throwing parts at it. Free test = Could very well be ignition. Pull a plug wire... Is it firing?
Hobo
Old Jan 18, 2021 | 05:03 PM
RLXXI's Avatar
RLXXI
Originally Posted by hobohilton
The combustion Triangle = fuel, compression, ignition.
Hobo
Corrected.
Old Jan 18, 2021 | 08:03 PM
hobohilton's Avatar
hobohilton
Originally Posted by RLXXI
Corrected.
___________
Doubtful that correction is helping this young man get his truck running...
Hobo
Old Jan 18, 2021 | 08:51 PM
RLXXI's Avatar
RLXXI
___________
Hobo
Fuel under the best conditions in an internal combustion engine is 14:1, that's (14 parts oxygen 1 part gasoline), O2+Gas = Fuel, that's if your engine is stochiometric which is the standard for optimal operation of said engine. Neither of which would achieve full potential in said engine until it's compressed, then ignited.
Old Jan 18, 2021 | 11:48 PM
ford2go's Avatar
ford2go
You might want to ask your question in the older trucks section -- you'll get a lot more detail. But about the restart -- that sounds like the computer is giving it the initial shot(2 seconds) of fuel. Then it's not getting the signal that the engine is running so it doesn't re-enable the fuel pump.
Not sure if the engine running signal is oil pressure or RPM, but that might be causing your problem. Some Fords from that era did need an oil pressure signal to keep running
The guys in the older trucks section should have a lot more info.
Good Luck,
hj
JessD209
Aug 6, 2023 08:33 PM
Orpackrat
1983 - 2012 Ranger & B-Series
Dec 27, 2009 08:23 PM
ottr1967
Nov 23, 2006 02:02 AM
70spoiler
20
Jan 14, 2006 08:42 AM
Nenzel
Jan 27, 2005 10:37 PM
