Fuel Issue
Old Jan 26, 2020 | 01:28 PM
JessD209's Avatar
JessD209
Question Fuel Issue
Hello, I have a 1995 F150 with a 5.8 Engine. I am having issues with i believe fuel delivery. When I start my truck is runs fine but when I attempt to drive it, its acting as it doesn't have fuel or the power to go. I replaced the fuel filter and the fuel pump it ran fine for about a week and then started acting up again. So i automatically think its my fuel pump again. I am wondering if maybe the wires are not done correctly or if something else can be causing this issue. My engine light is off.
Old Jan 26, 2020 | 02:09 PM
jas88's Avatar
jas88
Do you have dual tanks? If so, does it do it on both tanks?
Old Jan 26, 2020 | 03:28 PM
JessD209's Avatar
JessD209
No it only has 1 tank
Old Jan 26, 2020 | 03:33 PM
sandymane's Avatar
sandymane
Do you know how to pull diagnostic codes? If so I would do that. If you don't know how, I can send a video. It's easy. Sandy
Old Jan 26, 2020 | 03:36 PM
JessD209's Avatar
JessD209
Can you send me a video just so I know i am doing it right? Thank you so much!
Old Jan 26, 2020 | 03:39 PM
sandymane's Avatar
sandymane
You can just use a paper clip instead of the jumper wire he uses. Just run the key on engine off first and lets see what you get. Sandy Any questions or problems let us know
Old Jan 26, 2020 | 06:11 PM
jackietreehorn's Avatar
jackietreehorn
After you pull codes, check fuel rail pressure.
Old Jan 27, 2020 | 09:36 AM
subford's Avatar
subford
Did it have 2 tanks at one time?
Old Jan 27, 2020 | 12:48 PM
JessD209's Avatar
JessD209
Nope always had only 1.
Old Aug 6, 2023 | 08:33 PM
MBman's Avatar
MBman
opps wrong thread
Texican01
6.7L Power Stroke Diesel
Feb 20, 2017 10:40 AM
bigsteve-o
18
Apr 2, 2007 10:18 AM
87longbed150
Mar 24, 2007 09:14 PM
shawn
Jan 15, 2004 12:34 AM
