Shock question.
Old Jan 17, 2021 | 10:13 AM
Nmaykdm's Avatar
Nmaykdm
Shock question.
Hello guys I’m back and I’m doing a simple shock change. Iv put a two inch lift pucks under my coils in the front to level it out. I went a head and bought the bilstien 5100. They are a 4” in lift in the front and 2 in lift in the back. I’m wanting to know how level my truck is going to sit after I put them on. I know shocks are not enough to lift a truck alone so I’m hoping my front isn’t taller than back. I kinda thought I just loose a little shock travel before my truck sat nose high. Any thoughts are appreciated. Thanks
Old Jan 17, 2021 | 11:59 AM
Nmaykdm's Avatar
Nmaykdm
another observation is that my shocks haven’t been changed in about ten years. They are completely dead. You can play with em like a slinky. So if my original shocks are supposed to lift the truck even a little, they are not and my truck sits pretty level. It’s a rough ride tho.
Old Jan 17, 2021 | 01:00 PM
hobohilton's Avatar
hobohilton
Doubtful shocks will have any elevation change on your truck.
Hobo
Old Jan 17, 2021 | 01:09 PM
SFaulken's Avatar
SFaulken
Unless the shocks are of a design that has a spring incorporated into them (A coil spring Mounted on them, a coil-over, or an Air fitting to charge an "air spring" inside of them) they aren't going to affect the ride height of your truck at all. Well, unless you jam a shock that's compressed length is longer than the ride height of your truck in there, making it a solid suspension.
Old Jan 17, 2021 | 05:19 PM
Nmaykdm's Avatar
Nmaykdm
Thanks guys. That’s all need to know.
Old Jan 17, 2021 | 11:39 PM
TexasGuy001's Avatar
TexasGuy001
Are you saying the shocks you bought are for a 4 inch lift? If so you are better off with stock shocks for a leveling kit. The 4 inch lift shocks will be too long.
Old Jan 18, 2021 | 12:43 AM
Toork's Avatar
Toork
I had the same shocks on my 4 door JK. They shouldn’t affect your height.
Specializer
Dec 20, 2023 08:59 AM
Shwan_89HD
Sep 25, 2019 02:26 PM
konan
Apr 15, 2007 09:05 AM
dixiemudder04
15
Nov 15, 2006 08:53 PM
TXsnyper
Mar 5, 2006 07:15 AM
