Spare Key and Remote
Old Jan 16, 2021 | 10:49 PM
HorsePower Junkie's Avatar
HorsePower Junkie
Suggestions needed of where to get a spare key and a spare remote? And also where to get programming instructions.
Thanks
Old Jan 16, 2021 | 11:18 PM
ShelbyHauler's Avatar
ShelbyHauler
If you only have 1 key, you will need a dealer, a locksmith, or I think Forscan (sp)? I just recently paid a mobile auto locksmith $120 for a 2nd key and remote, including all programming.
Old Jan 17, 2021 | 03:35 PM
Excursion Gary's Avatar
Excursion Gary
Excursion's 4ever!
Programming the remote is VERY simple. Check youtube for video on your vehicle. In a nut shell get in the driver seat, close the door, press the door unlock button, insert key and turn to the "on" then "off" position eight times quickly ending in the on position. Then press any key of your FOB(s) and that will be it. Then turn key off and test.
I just got a two pack of remotes off Amazon for $14.95. Took me less than a minute to program them both.
Old Jan 17, 2021 | 03:39 PM
ShelbyHauler
And don't get the all in 1 key unless you want to remove the plastic from your ignition on the steering column as the all in 1 (key with built-in remote) is too fat to fit in the plastic collar.
Old Jan 18, 2021 | 03:59 PM
HorsePower Junkie
Thanks Guys!
Very helpful and very appreciated!
Where do you suggest I purchase a key? And is there any programming needed for the key?
Is the key a plain key that does not need any programming?
Old Jan 19, 2021 | 01:53 PM
unleashd's Avatar
unleashd
Originally Posted by HorsePower Junkie
Thanks Guys!
I bought blanks from Amazon. I had a Ford dealer program and cut them for me for free as the EX was in for other bigger $$ fixes
Old Jan 19, 2021 | 02:46 PM
ShelbyHauler
Thanks Guys!
The key has a chip and will require programming. If you have two keys already programmed, you can do the third, forth, etc on your own. But if you only have the one, you will need a programming device to program it.
Old Jan 19, 2021 | 09:22 PM
HorsePower Junkie
I only received the one key and one remote when I bought it a few months ago.
Old Jan 25, 2021 | 05:32 AM
HorsePower Junkie
Is there any work around if the Excursion only has 1 key?
If not, where do I find a programming device?
Will an Auto Parts store have one? Can I rent one if they are cost prohibitive to purchase one?
Thanks
Old Jan 25, 2021 | 09:06 PM
Mikei70's Avatar
Mikei70
My local Home Depot will do it-- but you have to buy the blank from them. Around $70 I think the last time I checked.
Old Jan 26, 2021 | 05:30 AM
WE3ZS's Avatar
WE3ZS
My memory is a little foggy on that (along with a lot of other things....) if you go that route does that give you a new "cloned" key that coupled with an original wont work to make more copies or does it give you a true unique key that can work with an original to make more copies?
Old Jan 26, 2021 | 07:56 AM
Mikei70's Avatar
Mikei70
That's a good question. I do not know.
I'll see if they know at Home Depot later today. It's next door to my job.
ehagerty
Dec 3, 2019 06:03 PM
K A M
May 1, 2017 10:08 PM
khadma
2015 - 2020 F150
Dec 24, 2015 05:02 PM
cchsbuzz19
General Automotive Discussion
Oct 12, 2014 09:25 PM
NukeUFO
2004 - 2008 F150
Sep 3, 2014 04:23 AM
