Those MAP and Baro readings sound a little low for inHg and a little high if PSI for KOEO.
btw - Mark.
Mark! I’m sorry - isn’t there some rule against late night internet posting? And now I’m posting in the early morning which might not be much safer considering how few hours ago I went to bed.
I will brave a question, though. I’m fairly certain those MAP and BARO numbers are inHg (yup, just checked again). I googled this before posting so I know it’s a thing. We are at about 2300 feet above sea level, which will make readings lower. The chart I found said to add 2.3 to inHg readings to compensate for elevation. Does that get closer to expected readings? I have a chart from Piolet that lists operating range as either kPa or PSI, expected readings of 96.5 or 14 respectively. I guess I could google that, too!
