mystery relay?? HELP
Old Jan 14, 2021 | 06:16 PM
4drocket's Avatar
4drocket
any one know what this relay is for? one wire to starter relay for power. then the ground was run all the way to the back of the truck and grounded to frame rail (found it while chasing down reverse light connector) and another wire goes into firewall and i tried to find it inside but its up too high and i am too big and too lazy today to take **** out to chase it down. hope someone knows...thx
Old Jan 14, 2021 | 06:17 PM
4drocket's Avatar
4drocket
oh yeah weird part is the ground wire had been cut near the ring connector it was grounded to, so am i right that it was not functioning since no ground? thanks again.
Old Jan 14, 2021 | 06:53 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
since I cannot see the connector on the Relay, I'm going to guess a General purpose relay like a Horn Relay
Old Jan 14, 2021 | 07:30 PM
4drocket's Avatar
4drocket
its on the firewall drivers side just under the hinge, do you have a relay there? am i correct in assuming that since the ground wire has been cut that its not functioning? thanks wolf!!
Old Jan 14, 2021 | 07:39 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
no My 93 does not have that Relay...
could it be connected with that other device that you showed that I thought looked like a heater of some type...
since you have turbo on yours.. I wonder if you might have Propane injection.
Old Jan 14, 2021 | 08:05 PM
DarkOverCast's Avatar
DarkOverCast
This would be my guess as well. Kinda like that other guy here that found a water meth injection kit on his idi
Old Jan 14, 2021 | 09:46 PM
4drocket's Avatar
4drocket
that would be awesome but i doubt it
no its not connected to that deal below it.
theres a hot wire from starter relay.
a ground wire which they ran all the way to the back just before rear wheels only to ground it on the frame rail.
a smaller wire goes thru firewall just behind the brake booster which looks like a drilled hole (not factory).
the ground wires been cut for a while so do u think its safe to say its not functioning (something i can remove)?
thanks guys
Old Jan 14, 2021 | 10:24 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I can for sure say it is not Factory maybe it was for an AUX battery on a trailer or some other Accessory that the Original owner had. It's just hard to say.
Arizona97
Mar 18, 2017 10:16 AM
19tanker
Dec 22, 2013 08:03 PM
jhaas63
18
May 3, 2013 04:04 PM
Ford'05HG
Electrical Systems/Wiring
Dec 5, 2012 04:38 PM
Boss429F150
Oct 28, 2008 05:54 PM
