Air Intake Relay Bad?
Old Mar 17, 2017 | 02:02 PM
Arizona97's Avatar
Arizona97
While doing a visual inspection I noticed that the AIH hot wire (captured nut wire) had broken off and was laying loose. I removed the wire from the relay and made a new 8 gauge wire, I connected it to the relay and was about to add it to the AIH when I got a healthy spark ( it touched the ground wire ) and yes the truck was not running and the key was out at the time.
This sounds to me like the relay has gone south, am I right???
I have a new OEM relay to install but I have a question. In what order are the wires and ceramic fitting go on the AIH post???
Thanks for your help
Ed
Old Mar 17, 2017 | 03:23 PM
Steve_250's Avatar
Steve_250
Are you in an area where you need the AIH?
I'm in MD and I removed the guts years ago.
I keep the relay there as a spare glow plug relay.
Old Mar 17, 2017 | 03:46 PM
Arizona97's Avatar
Arizona97
Hi Steve, It's not so much that I need it here in Arizona. I just would like some answers to my questions.
Thanks for your reply.
Ed
Old Mar 17, 2017 | 04:28 PM
Dirtscooter250's Avatar
Dirtscooter250
Ed
what is the resistance across the two large terminals? If the relay is stuck on or there is a short to ground on the relay coil and 12V on the control side it will show some resistance with the relay off. There should not be voltage present on the opposite terminal to the hot wire AND no continuity between terminals.
Also check the two control wires. One should be open and one should be 12V. Computer controls ground signal to relay.
Old Mar 17, 2017 | 05:24 PM
Arizona97's Avatar
Arizona97
Hi Dirtscooter, good job, I think you hit the nail on the head, I did not think there should be power to the opposite terminal from the power terminal when the truck was off (thus the sparking on the ground wire) when I checked the relay the next morning there was not power to that terminal.
Now care to take a shot at In what order are the wires and ceramic fitting go on the AIH post? I am thinking Ground Wire First, Then Ceramic Insulator and then Hot/Power wire from the relay. Am I right?
Thank you for your help
Ed
Old Mar 17, 2017 | 06:05 PM
Dirtscooter250
Ed
Correct! I was going to take a pic but it is self explanatory. Ground first, insulator, positive and nut!
Old Mar 17, 2017 | 06:07 PM
Rikster-7700's Avatar
Rikster-7700
In theory, it should make a difference I don't believe. It is just a resistor and all it needs is the 12v of potential difference across it to work.......
Old Mar 17, 2017 | 06:12 PM
Dirtscooter250
Technically that is true however if you put 12v on first your whole entire spider would have 12v on it if the relay failed closed and also when the relay activated.
Old Mar 17, 2017 | 06:37 PM
Rikster-7700
That is a good point, I didn't think about that...
I have never had mine out so I didn't know it wasn't insulated from the spider / housing.
Old Mar 17, 2017 | 06:39 PM
Arizona97's Avatar
Arizona97
Dirtscooter, you are a life saver, thank you very much for your input. Tomorrow is Saturday looks like I have some lite Mechanical work to do. Also I am going to replace my Glow Plug Relay while I am at it, 251K miles it is still going through the terrible 2s.
Thanks Again
Ed
Old Mar 17, 2017 | 09:04 PM
Dirtscooter250
Thanks Again
Ed
Glad I could help! Did you get the gpr109 or stancor 586?
Old Mar 18, 2017 | 10:16 AM
Arizona97's Avatar
Arizona97
Dirtscooter, I just went with the Motorcraft gpr109---OEM baby!!
Thanks Ed
seagiant
Oct 4, 2017 10:44 AM
DrZoom
15
Jan 12, 2017 06:25 PM
timmyboy76
Oct 24, 2011 07:08 PM
Jessef250
Jan 9, 2011 05:06 PM
kilapapipa
21
Feb 11, 2009 07:55 AM
