Need help,, Installing Dashcam
Old Jan 19, 2021 | 10:41 PM
Kingofwylietx's Avatar
Kingofwylietx
Originally Posted by Fordy20
It’s the outlet right next to the USB port. There’s a small blue light in the plug from the dash cam
that stays on. It takes quite a while after you shut the truck off before the dash cam turns off. Several minutes.
That power point is also timed, I don't know the exact number of minutes. I think the only power point that stays on constantly is the one inside your center console. You can use a jumper to let other power points do the same.
Old Jan 20, 2021 | 06:06 PM
Fordy20's Avatar
Fordy20
Well, that makes sense. Don't see any use to monkey around hard wiring when that works just as good.
smr camper
Dec 17, 2020 07:27 PM
JethroF250
17
Jul 21, 2009 08:29 PM
custom_nirvana
Feb 3, 2008 01:19 PM
BLACK350/6.0L
May 12, 2005 11:16 PM
wiggit
Electrical Systems/Wiring
Dec 6, 2004 12:40 AM
