Leaky oil filter
Old Jan 14, 2021 | 09:36 AM
DeeDubz's Avatar
DeeDubz
Leaky oil filter
I noticed a few drops of oil in the place I park my truck. Luckily it wasn't concrete and just rock. After pulling my truck into the shop I saw that oil was leaking from where the filter connects to the housing. I remember having this issue a few yrs back. I hate vehicles that leak oil. Im not sure if its the type of filter or what. I tighten usually 1 3/4 or two turns. The type of filter I have on it now is a motorcraft. Anyone have this issue? What filter do you guys recommend. I dont want my truck to turn into some **** bags truck that leaks oil everywhere.
Old Jan 14, 2021 | 10:27 AM
ford390gashog's Avatar
ford390gashog
Its the filter, these filters have a tendency to weep oil on these engines.
Old Jan 14, 2021 | 10:36 AM
DeeDubz's Avatar
DeeDubz
what filters do you run?
Old Jan 14, 2021 | 11:13 AM
dirthawg's Avatar
dirthawg
My Motorcraft FL2051's do the same, I usually notice the oil stains running down the sides of the filter. I only hand tighten the filter.
Old Jan 14, 2021 | 11:21 AM
Just Strokin's Avatar
Just Strokin
Lots of times it is not the filter leaking but oil on top of the filter that is drips/runs onto the filter in the indention between the seal area and the outer crimp area. This oil gets blown from that area as you drive it and appears to weep. Take some brake cleaner and clean the area solves the problems more otren than not.
Old Jan 14, 2021 | 12:59 PM
djousma's Avatar
djousma
When I change my oil the rubber gasket from the old filter occasionally is stuck to the housing. So, if doubled up on new filter, you will get a slow leak too. More likely what the others have however.
Old Jan 14, 2021 | 01:08 PM
mjs2011's Avatar
mjs2011
My oil filter leaks as well, and I haven't found a fix yet in the 5 oil changes I've done so far. No drips on the pavement, but a wet and dirty filter body.
I make absolutely sure that the old gasket isnt still stuck up there, make sure the filter mating surface is clean and that the gasket on the new filter is lubed properly, I've tried the recomended number of turns vs. tightening by hand as much as I can. No matter what, my filter always is dirty by ~500 miles into the oil interval.
Old Jan 14, 2021 | 01:25 PM
machmedic's Avatar
machmedic
I had a similar problem on my truck last year. Turned out the filter gasket was dry rotted with cracks. New filter fixed it. I was surprised as the leaky filter I got from dealer.
Old Jan 14, 2021 | 01:51 PM
tradosaurus's Avatar
tradosaurus
The first and only time I doubled up on the oil filter rubber gasket I blew about 4 qts of oil on the driveway.
Now I'm religious about checking to make sure the old gasket isn't stuck .
Old Jan 14, 2021 | 02:33 PM
DeeDubz's Avatar
DeeDubz
Yep I did that when I changed the oil in the wifes explorer. I didnt check to make sure the filter was off..... I double the filter not knowing it. It made a mess.....
Old Jan 15, 2021 | 06:01 PM
The Bone's Avatar
The Bone
Originally Posted by Just Strokin
Lots of times it is not the filter leaking but oil on top of the filter that is drips/runs onto the filter in the indention between the seal area and the outer crimp area. This oil gets blown from that area as you drive it and appears to weep. Take some brake cleaner and clean the area solves the problems more often than not.
I talked to my Ford guy because I had drips on my oil filter and it's because if they dont let the filter area stop dripping than they can get some oil on top of the filter. As you drive it will run down the side of the filter. I always remove the filter first then drain the pan.
Old Jan 15, 2021 | 06:15 PM
FishOnOne's Avatar
FishOnOne
Here's an oil change video and at around 10:30 the tech cleans the residual oil on top of the oil filter to prevent this oil from dripping down later. The key is to not allow any of the old oil to get on top of the oil filter during filter installation.
Old Jan 16, 2021 | 07:29 PM
speakerfritz's Avatar
speakerfritz
check to make sure there are not 2 gaskets in there...sometimes the old filter gasket sticks to the engine.
Old Jan 17, 2021 | 09:08 AM
CP Dubbs's Avatar
CP Dubbs
FL2051 is made by Purolator, and is nothing exotic or special. Part of Mann-Hummel now, and QC is out the window in trade for shoving product out the door.
I run Donaldson P502503.
I've looked inside a Champion Labs made LuberFiner LFP2051.
If I couldn't get Donaldson, LuberFiner is on the short list.
LuberFiner
Old Jan 18, 2021 | 10:40 AM
speakerfritz
LuberFiner
what’s the micron rating?
