engine swap- replace injectors?
Old Jan 13, 2021 | 01:14 PM
Black Beauty 250's Avatar
Black Beauty 250
Trailering
1988 f250 w/ 200,000+ -am swapping with reman long block- wondering whether i should replace injectors as a matter of course or can simply move old fuel rail and injectors to new engine- thanks
Old Jan 13, 2021 | 01:22 PM
Mikulh's Avatar
Mikulh
I just finished swapping from 300 to 351. I didn't replace the injectors in the 351, but I did clean, rebuild, and test them using the instructions in this thread.
https://www.ford-trucks.com/forums/1...to-thread.html
Old Jan 13, 2021 | 02:01 PM
Conanski's Avatar
Conanski
The original EV1 injectors are nearly indestructible and have an almost unlimited lifespan, but they do get contaminated with dirt and varnish which reduces performance so an overhaul and bench cleaning is definitely recommended.
Old Jan 16, 2021 | 07:36 PM
midwestbird's Avatar
midwestbird
For what it's worth, I had my injectors flow tested and ultrasonically cleaned ($25 each) by a local shop. It made a significant difference in throttle response.
Old Jan 17, 2021 | 09:20 AM
Scndsin's Avatar
Scndsin
Or you can get a set of these new. Less than list if you get a coupon.
https://lmr.com/item/LRS-37262/musta...ype-3-8604-ev1
Usmc6.0
May 18, 2017 09:24 AM
charecter1
18
May 6, 2016 10:46 AM
RZAR
Aug 11, 2015 09:36 PM
luisduran
17
Aug 22, 2010 01:08 PM
blaze42069
Dec 28, 2008 03:14 PM
