Possible new owner here
Old Jan 13, 2021 | 07:09 AM
ogaddcb's Avatar
ogaddcb
4wd High
Looking at a 2020 F250 4X4 S/C. XL DECOR PACKAGE 6.2 Ls V8 and a 3.73 ELECTRONIC-LOCKING AXLE. Two quick questions I have not been able to find out the answers.
I am familiar with ARB air lockers but not with ELECTRONIC-LOCKING AXLEs. Will the ELECTRONIC-LOCKING AXLE stay engaged when in four-wheel drive High, four-wheel drive Low and in reverse?
What do I look for to see if the factory solution to the “death wobble” has been installed on the truck?
Old Jan 13, 2021 | 07:46 AM
Joe T's Avatar
Joe T
2020 should have the revised steering stabilizer. The trucks with heavy service or snow plow front springs seem to be more prone to the shake (sit higher without caster adjustment).
The rear Elocker works till 25mph I believe. Its a true locker.
Old Jan 13, 2021 | 08:11 AM
chamdaddy's Avatar
chamdaddy
Page 220 of the manual.
• The electronic locking differential will
not engage if your vehicle speed is
above 20 mph (32 km/h) in 4x2, or 4x4
High modes.
above or 56 mph (90 km/h) in 4X4
Low.
Old Jan 13, 2021 | 09:01 AM
Desert Don's Avatar
Desert Don
Nothing to look at. There hasn’t been one. If Ford announces an “upgade”, then how many will they have to retro-fit? Everything since 2017? They aren’t going to do that unless Big Brother forces them.
Old Jan 13, 2021 | 09:13 AM
stephen.osborne1's Avatar
stephen.osborne1
In reality, the number of vehicles truly experiencing death wobble is very minor when you look at how many of these trucks are on the road.
On the locker, it is manually engaged with the 4x4 shift ****. You can be in 4x4 hi or low with or without the locker. It will disengage once you exceed the aforementioned speeds. I think someone found a way to adjust this in Forscan, IIRC.
Old Jan 13, 2021 | 09:20 AM
ogaddcb's Avatar
ogaddcb
4wd High
Thanks. Great info. Got some thinking to do. Will add these comments to my decision tree.
Old Mar 31, 2021 | 12:39 PM
ogaddcb's Avatar
ogaddcb
4wd High
Well, it seems that if I wanted a 4-door Lariat, King Ranch or Platinum with a regular bed I could have had my pick off the lot at several dealerships. But I wanted a XT Super Cab , 7.3 gas, 4-wheel drive with 4.30 ELocker gears. Had to order it with a 30-90 day wait for a 2022. So, at least it gives me plenty of time to take all the STUFF off my current truck. Count down started 03/22.
Old Mar 31, 2021 | 07:12 PM
Big Sky's Avatar
Big Sky
So after 20 MPH you have no type locking diff/limited slip, correct?
Old Mar 31, 2021 | 07:29 PM
ogaddcb's Avatar
ogaddcb
4wd High
From what I deduce that is correct. Unless like poster stephen.osborne says the person who found a way to adjust this in Forscan, IIRC has the work abround.
Old Mar 31, 2021 | 07:31 PM
h20camper's Avatar
h20camper
If you're in 4wd low, it will up until 56 mph. Not sure what it would be like driving in 4wd low at 56mph+
Highboy74
Ford Truck Parts for Sale
Feb 2, 2012 09:08 PM
Joe Finn
Aug 16, 2011 07:25 AM
swampRat32331
17
Oct 22, 2008 12:18 PM
jerm3
Jul 4, 2005 08:45 PM
Brian77
Nov 9, 2003 06:19 PM
