Question
Old Nov 4, 2003 | 07:56 AM
Brian77's Avatar
Brian77
Question
I'm looking for a reverse rotation rear axle that I can make fit a CJ. What year and model of vehicle should I be looking for. I'm assuming it would be a D60? The front will be a D44 from a 77.5 to 79 3/4 ton F250. I need to get my pinions up in this short wheelbase rig. Any advice is appreciated.
Brian
Old Nov 9, 2003 | 06:19 PM
buzzbait65's Avatar
buzzbait65
it is not exactly a "reverse rotation" axle , you are thinking of a "high pinion" axle , they take a front ford high pinion axle center section and gears ( they also make new ones just for this)and put rear axle tubes and wheel hubs in it for the rear application.......very expensive, not easy to find, you are better off (cheaper anyhow) to just get a GOOD QUALITY high angle c-v drive shaft built, and use a regular axle. but if you have the cash it can be done, in fact you can get a high pinion ford nine inch made, very strong, lighter and smaller size
