f250 reverse shackle
Old Jun 3, 2005 | 02:14 PM
jerm3's Avatar
jerm3
Well this didn't get much attention in the chasis-axle forumn... odd, so i'll try here. In the search for a somewhat smoother ride, i found some threads here about the reverse shackle kit but was bummed to find out its only for solid axles. So is it worth it swapping axles to install the reverse shackle kit and if so where's the best place to get a solid axle from (internet or junk yard)? I was planning on lifting my truck 2-3" anyways. 1997 F250 PSD 4x4 btw
Old Jun 3, 2005 | 05:07 PM
Max1775's Avatar
Max1775
If you're serious about off-roading, the solid axle swap is the way to go. Be prepared, it's not gouing to be cheap. You can try junk yards, but you may want to consider a custom axle from Dynatrac.
Max
Old Jun 3, 2005 | 08:37 PM
jerm3's Avatar
jerm3
thanks. looks like i'll start storing my change in a penny jar now and see what comes first, the money to do this swap or just find a f350 exactly like my truck.
Old Jun 4, 2005 | 05:59 AM
Robert6401's Avatar
Robert6401
This is just for my own knowledge so I apologize in advance for asking such a dumb question, but what kind of setup does the 97 model have if not soild axle? TTB? Sorry again, but thanks for edumacatin' me
Bob
Old Jun 4, 2005 | 10:34 AM
Max1775's Avatar
Max1775
Yep, TTB. In 99' ford started putting solid front axles under all superdutys, before then the 250's had TTBs. Not a dumb question at all, personally I think it was dumb of Ford to put anything but a solid front axle in a 4X4. At least they're doing it right now...
Max
Old Jun 4, 2005 | 10:45 AM
Rowdyone's Avatar
Rowdyone
You know I have seen a few of the independant front axles that guys have taken and welded them up making of sorts a square tubing type of solid axle out of them by b oxing them in.
Heck, if you can weld much at all, you could do this easy enough and then shackle the axle as it should be. I have finished the reverse shackle on my 95 F350 that I built the shackle kit myself, but I weld better than most. Really was not that bad a job and actually quite fun. I think the welding up the axle like what you have would be easy and fun as well. Might be something you would be interesting in...
Old Jul 3, 2005 | 12:20 PM
Jerryz's Avatar
Jerryz
Shackle reversal
Call up the guys at OFF ROAD UNLIMITED. They sell a shackle reversal kit.
Also if your looking for a better ride there are a few airbag kits out there.
Currently thinking about a shackle reversal for my f350 and using f250springs should net about 2-3 in of lift and a better ride.
Old Jul 4, 2005 | 08:45 PM
soutthpaw's Avatar
soutthpaw
good idea
I had not reall thouht about welding the 2 axles togather but it make sense and cheaper than swapping out to a straight axle
do you have any pics you can send me of doing that
Bansheesandrider
Oct 14, 2012 02:30 PM
rn360908
Sep 28, 2010 11:06 PM
Fullcrew7.3
Offroad & 4x4
Nov 18, 2009 01:19 PM
whitefordaward
Offroad & 4x4
Jan 31, 2007 08:18 PM
barebackjake
13
Mar 22, 2005 05:36 PM
