Ballast resistor location
Old Jan 12, 2021 | 05:38 PM
chiefdave's Avatar
chiefdave
I upgraded the distributor on my '62 223 I6 with a unit from a 240/300 to get the mechanical advance function. The performance increase was noticeable but now I'm suffering from condenser failures, one might last 2 months if I'm lucky. The local parts house said out of the box failures on the foreign manufacture condensers is high. I've decided to upgrade to a Pertronix Ignitor II system complete with new coil. The problem is locating the ballast resistor under the dash so it can be removed and get the full 12V to the coil. I've tried to trace wires and can't find anything that looks remotely like a resistor. There has to be one as voltage at the coil reads 5.57V. Any help?
As a side note my '49 has a Mallory flat top dual point distributor with a 60+ year old condenser that is still going strong.
Old Jan 12, 2021 | 05:49 PM
Becky_is_a_66's Avatar
Becky_is_a_66
I changed both our 66 trucks to electronic ignition HEI distributors. The resistor on both those trucks was a pink wire - didn’t look like a resistor - just looked like any other wire. I suppose resistance was simply engineered into the conductor within the wire. I disconnected it and ran a regular 12 gauge wire from the ignition switch. I cannot speak to your year model, but it is possible it has the same setup.
Old Jan 12, 2021 | 07:02 PM
66F250_4x4's Avatar
66F250_4x4
I was looking into the same thing - I found good info on resistor wires in the '73 forum here:
https://www.ford-trucks.com/forums/1...stor-wire.html
Old Jan 12, 2021 | 07:06 PM
Tedster9's Avatar
Tedster9
It's called "pink wire" and is connected directly to the ignition switch via bullet connector. Sometimes marked "Do not splice or cut" iirc. It is a "steel" or maybe nichrome, something like that stranded wire with a heat resistant insulation. They get hot. When it exits the firewall into the engine bay, it is regular stranded wire I think. So it looks just like part of the wiring harness under the dash, because it is.
Old Jan 12, 2021 | 07:12 PM
AZ66F100's Avatar
AZ66F100
Just bypass the pink wire with a regular wire. It runs from the ignition switch to the coil. You don't even need to remove it.
Old Jan 13, 2021 | 10:41 AM
6t6merc's Avatar
6t6merc
Or use the resistor wire to operate a relay.
624WD
Nov 23, 2020 01:35 PM
mountain dewd
40
Apr 30, 2016 10:33 AM
672wd72highboy
Jun 18, 2014 03:59 PM
46yblock
Apr 15, 2006 06:39 AM
ford_nut
Jul 11, 2002 04:00 PM
