burning up coils?
Old May 23, 2014 | 07:22 AM
672wd72highboy's Avatar
672wd72highboy
burning up coils?
I have a 72 f250 highboy the 360 in it was vapor locking. When it stopped that after new plugs wires distributor and fuel pump. It just died acting like no spark. Once I put a new coil and battery truck started and ran. Drove abt 4 miles parked it the when I tried to start it again bam right back to no start any idea's?
Old May 24, 2014 | 10:37 AM
stevejohnson48's Avatar
stevejohnson48
Burning coils up ??/
Are you using a coil with the resister in the coil or a external resistor ??/ or are you familiar that you even need to use a resister between the coil and distributor ??/ What are you running points ,Duraspark, other ??/ what do your points if your running points look like after you lose your coil ??/ Are you using a cheap after market coil ??/ Any combination of these occurrences could cause you problems not saying that's the cause of your failure but its a start ??? Also each system ( Distributor ) uses a different OHM resister some may not even need one( Mainly the electronically triggered ones ) ??/
Old May 24, 2014 | 08:49 PM
672wd72highboy
Well yes I'm using a resistor on the distributor and it is points. I need to check the points again but they were brand new with the distributor. Also have a resistor by voltage regulator.
Old May 27, 2014 | 06:50 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Sounds like you are confusing resistor with capacitor/ condenser. The tubular part in distributor is the condenser, one by voltage reg is a noise filter. The resistor wire is behind the dash in the wiring harness between ign switch and firewall. My guess is you have replaced coil with the wrong one. Most are marked for use with internal or external resistor. For use with external resistor is the one you need. Primary reading across +/- posts should read about 1.4 ohms. Standard for all older Ford vehicles, points or Duraspark.
Old Jun 18, 2014 | 01:04 PM
672wd72highboy
I've tried both types of coils to be honest and no luck so bought a ballast resistor and now can't find it under the dash a few people have mentioned a resistor wire?? Can I just run a new hot wire from ignition to coil and put a resistor in that wire?
Old Jun 18, 2014 | 01:06 PM
672wd72highboy
Oh and another question which wires go where on the coil +/- my 67 was backwards from my 72 what is the correct way
Old Jun 18, 2014 | 02:34 PM
Tedster9's Avatar
Tedster9
Condensers (and coils) often fail only when they reach operating temperature. Something to beware of.
Old Jun 18, 2014 | 03:59 PM
redroad's Avatar
redroad
Is the battery secured in a way where it can't bounce and make contact with the hood etc. ?
marcusoliver
Jan 30, 2018 10:10 PM
r_reed
Aug 13, 2016 08:15 PM
mountain dewd
40
Apr 30, 2016 10:33 AM
eclypseballoons
Electrical Systems/Wiring
May 22, 2008 07:29 PM
flipklos
May 4, 2008 12:43 PM
