Sponsored by: Real Truck
Radiator side covers
Old Jan 10, 2021 | 08:52 PM
bryyce62's Avatar
bryyce62
Doing some routine maintenance on my '13 6.2.
Between the radiator sides and the headlights, behind the grill is some paper-like material that has disintegrated. Kind of reminds me of tar paper. I'd imagine it's some kind of air shield. Anyway this material has basically rotted away.
Couple questions.
Is this something I should replace?
And what would be the part number if did want to replace this?
Thanks for any help.
gw
Old Jan 10, 2021 | 08:59 PM
muhford's Avatar
muhford
Same thing happened to my 2010. I just pulled it all out and threw it away. I would guess Ford put it there to lower the dB to make the EPA happy. They did something similar with my F150. It had a giant piece of hard carpet hung under the engine. Served no purpose.
Old Jan 11, 2021 | 05:56 AM
Just Strokin's Avatar
Just Strokin
If does serve a purpose. It insures the air flow through the radiator and not around it.
Old Jan 11, 2021 | 01:39 PM
bryyce62's Avatar
bryyce62
That's kind of what I thought.
I'd like to replace them, just can't find a part number on the couple of ford sites I've searched thru.
EDIT:
After some more searching I think I've answered my question. They're side air baffles.
BC3Z-8310-A
BC3Z-8311-A
Old Jan 11, 2021 | 01:46 PM
Just Strokin
They are called Baffles. Check here...
https://parts.autonationfordwhitebea...diator-support
Old Jan 11, 2021 | 02:13 PM
bryyce62's Avatar
bryyce62
Smile
Thanks for the help JS. Found things the same time as you did.
Old Jan 11, 2021 | 02:43 PM
muhford's Avatar
muhford
Been running without the flaps for years without overheating. Maybe you're thinking of a fan shroud or something. OP is talking about the thin rubber sheets in front of the rad that fall apart after 2 years.
Old Jan 11, 2021 | 02:58 PM
Just Strokin
No, I know what he was talking about. Just because you have never had any issues, doesn't mean someone else will be as lucky. Also, he has a different engine than your 5.4 that might need the baffles when towing.
Old Jan 11, 2021 | 03:55 PM
bryyce62's Avatar
bryyce62
While I wasn't excited about the price to replace these baffles, which are nothing more than some die cut construction paper, I got both left & right sides on order.
thanks for the help.
Old Jan 12, 2021 | 08:11 AM
Fefanatic's Avatar
Fefanatic
I had a issue with a '12 6.7 air conditioning overheating the condenser and had high pressures. Replacing those baffles took care of the problem. They are there to stop airflow from circumventing radiator and other coolers. Properly installed they do work.
Old Jan 12, 2021 | 08:28 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I was going to say...anything around the radiator and other coolers that looks like it directs air into said devices...are there for a reason. And for most people who never tow anything, they're not needed. But if you start having issues or are towing, you want as much air going into those systems as possible.
Old Jan 12, 2021 | 11:18 AM
Mike1's Avatar
Mike1
Next time you might want to think about using something like this:
https://www.homedepot.com/p/GAF-Tri-...9000/310500811
I usually have a roll laying around and I just cut out what I need, usually double it, glue it together pop my holes. If you only ever use it on your truck then you're probably set for life with one roll.
raye321
16
Jun 28, 2020 05:13 PM
2jhanna
2009 - 2014 F150
Dec 11, 2016 04:13 PM
cwilliamp
2009 - 2014 F150
Mar 7, 2016 02:06 PM
RJP66F100
21
Mar 4, 2011 05:10 AM
Decoder01
17
Nov 5, 2010 08:21 AM
