Number Dummy help if possible, please
Old Jan 10, 2021 | 08:43 PM
sddaltongang's Avatar
sddaltongang
Question Number Dummy help if possible, please
Part number identification please?!?
EDD6TADA
RH041P
This was on my 78 F250 XLT Ranger Styleside front end, but someone used a 'torch' on it likely to loosen a nut & it has an irregular shaped hole which I am not sure I can repair adequately. Plus I am not sure if the deeply pitted bushing hole needs repair or replacement.
I will try to attach a picture.
Old Jan 10, 2021 | 09:08 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
No idea where it goes...on the other hand is that a frame bracket attachment point for the RH radius arm long part (3B095 is the L/H #) ? And it would of been held on with rivets or maybe nut and bolt? About any local machine shop should be able to weld/grind/drill and get you back in business quick. As far as that "deeply pitted bushing hole" depending on just where it goes it does not look that bad.
Old Jan 10, 2021 | 09:11 PM
caravaggio2000's Avatar
caravaggio2000
radius arm bracket?
https://www.ebay.com/itm/1973-1979-f...cAAOSw-BJfrBhT
Old Jan 10, 2021 | 09:16 PM
caravaggio2000
If so, someone probably tried to burn the rivet out. I wouldn't worry about it except to use a washer. As for the bushing hole, I would be completely filled with a big poly or rubber bushing, so I wouldn't worry about that either.
Old Jan 11, 2021 | 10:23 AM
sddaltongang
Thumbs up thank you!!!
Thank you Gentlepersons! I am sure you are correct & I am reoriented & reassured to be on the right track. Thanks again!!!
mercdiesel
Large Truck
Nov 6, 2020 04:55 PM
Whitiecars
Aug 22, 2020 03:17 PM
tweeter1148
Mar 19, 2020 11:54 AM
Branden Heine
Sep 19, 2019 09:37 PM
silverbullet6oh
Mar 10, 2017 11:17 AM
