HVAC control unit no power
Old Feb 2, 2021 | 07:42 PM
  #31
donmi's Avatar
donmi
Originally Posted by alloro
FYI, there is no connector between those two points, but there is one splice.
When I click the location for the splice all it says is: "Location: Wiring harness - Main (14401) near T/O to, C270f"
Maybe that makes sense to you, I know it doesn't make much sense to me.
The splice is called S241 and "C270f" is a connector on the CJB, so the splice must be close to there, see the attached files.
I am still convinced, the issue is based on moisture / corrosion in the CJB, Without a load, there is power on Pin 16, with a load not, typical for a lose / corroded connection. And when I checked the CJB for blew fuses, I found quite a bit of white powder from corrosion. This car was parked over 3 years outside without any usage and British Columbia can be very wet.
I will take the CJB out on the weekend and give it a good clean.
File Type: pdf
File Type: pdf
Old Mar 25, 2021 | 10:05 PM
  #32
donmi's Avatar
donmi
Water and CJB
Ok, Guys, yes, I am still alive.... Now the weather is getting better and I took another run on my problem.
Today I took the fuse box out and took it apart. I found lots of corrosion and during removing of the connectors from the fuse box I found actually wet cables / connectors.
Can somebody tell me, where the water most likely comes in and what is the solution??
Thank you!
Old Mar 26, 2021 | 05:55 AM
  #33
projectSHO89's Avatar
projectSHO89
All are symptoms consistent with LWS - Leaky Windshield Syndrome.
You'd probably also need to pull the kick panels and inspect the grounding connection points for corrosion, rust, and body rot.
Old Mar 27, 2021 | 07:38 PM
  #34
donmi's Avatar
donmi
Ok, took the fuse box out, disassembled it, cleaned is and used dielectric grease on every contact and it is now back in.
I also covered all windshield edges until I get a new windshield.
BTW: problem with the HVAC panel is still there, so I will pull a new wire in and get the power to the panel.this way.
I also had always a parasitic draw from the battery, today I measured it, it is 0.117 Amp, I pulled every fuse and checked, no change, still 0.117 Amp.
My Navi has a third party alarm system with remote starter.
What would be a "proper" draw??
Old Mar 28, 2021 | 06:24 AM
  #35
projectSHO89
After the thing goes to "sleep", about 35-45 minutes after any touch of anything, quiescent current draw should be under 50 mA. This is exclusive of any add-on circuitry.
Old Mar 28, 2021 | 01:53 PM
  #36
donmi's Avatar
donmi
I pulled already every fuse to check, no change.
Any idea , how to find out??
Old Mar 28, 2021 | 02:52 PM
  #37
projectSHO89
Did you wait the REQUIRED time after touching ANYTHING before making your measurement?
Old Mar 28, 2021 | 06:46 PM
  #38
donmi's Avatar
donmi
I waited 60 minutes, but I did a mistake, so I will do it again. Here is my way:
- After shutting the engine off, I will open the passenger door as I need access to the fuses
- close manually the door lock in the passenger door so the system thinks it is closed.
- open the hood
- remove the cable from the hood pin of the alarm
- power lock the doors with the remote
- wait 60 minutes
- wrap a blank cable around the negative pole of the battery
- connect a second blank cable to the negative cable
- connect both cables to an ampere meter
- NOW i disconnect the main negative main cable from the battery and make sure, the "homemade" shunt does not get interrupted.
- reading the meter and pull one fuse at a time and look for the difference on the meter.
- after that without "findings", disconnect the alternator and the starter and non-OEM accessories (Alarm and one audio addition)
I hope, I forgot nothing...........
HRTKD
All Things Towing
Feb 13, 2020 12:24 AM
mybitta1
Jan 27, 2013 02:36 PM
flyin 51
Nov 9, 2010 10:20 AM
jkrpec
Apr 7, 2010 10:29 PM
Zayazz
Apr 6, 2006 02:58 AM
