Forscan troubles
Old Jan 8, 2021 | 05:50 PM
FastTaurusSHO's Avatar
FastTaurusSHO
Forscan troubles
OK, so I bought the OBDlink CX (the MX is no longer available on Amazon) I tested it out on my 1996 Bronco first, and it wouldn't connect. Then I jumped over to my 2018 SD, and it connected, fired up Forscan and....nothing, kept getting the error saying no ELM found, and tried countless different settings. So I'm returning to Amazon, and thinking I'll get a wired OBD to USB dongle, and cross my fingers whatever I buy will work with Forscan.
Any advice for me? I was so frustrated today, 0 for 2.
Old Jan 8, 2021 | 05:54 PM
ford390gashog's Avatar
ford390gashog
Old Jan 8, 2021 | 06:07 PM
Dirk_Pitt's Avatar
Dirk_Pitt
I used mine today, get this, update the firmware, don't worry about a switch to flip, and sleep well at night...
OBDLink EX USB Scan Tool for FORScan - PC & LAPTOP - SCAN TOOLS
Old Jan 8, 2021 | 06:12 PM
Je942010's Avatar
Je942010
I'm using the same one and its fast and easy to use. No switch to worry about doesn't seem like a big deal but it makes the whole process that much easier.
Old Jan 8, 2021 | 07:22 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
CX is for BMW only
https://www.obdlink.com/products/obdlink-cx/
Motown Fire's Avatar
Motown Fire
I used the same adapter. Works perfect.
Old Jan 9, 2021 | 10:42 AM
Gomerpyle's Avatar
Gomerpyle
One thing I might add. Make sure you have newest version of Forscan. I ran into issues myself with an old version. Just FYI.
Old Jan 9, 2021 | 01:27 PM
4wd6.7L's Avatar
4wd6.7L
I had to look up the OBDLink CX, it doesn't look like its geared toward use on Ford or FORScan. Like you said OBDLink MX is gone, the MX+ is the newer version.
Old Jan 10, 2021 | 09:37 AM
sstock1's Avatar
sstock1
make sure you have updated driver's for the obdlink
Old Jan 10, 2021 | 01:52 PM
GNR22's Avatar
GNR22
OBDLink EX is what I'm using. No issues.
ryan robles
2009 - 2014 F150
Oct 29, 2020 01:45 PM
TexasStroke
Mar 13, 2020 09:02 AM
Jeff64F100CrewCab
Aug 4, 2019 01:47 PM
F2502011
Jun 5, 2017 12:58 PM
Kerrie
Feb 4, 2008 09:55 PM
