How much retaining compound to replace injector cups?
Old Jan 8, 2021 | 04:23 PM
One Sock's Avatar
One Sock
I'm going to be replacing all 8 of my injector cups. On Rock Auto they have a .2 ounce tube of Permatex 64000 sleeve retainer compound for $5. Local stores don't have this (or Loctite 620) in stock. Is .2 ounce enough to do all 8 cups or should I get 2 of them?
Old Jan 8, 2021 | 04:28 PM
ebbnflow's Avatar
ebbnflow
I used the bottle from riffraff. Loctite 620 0.34 oz. I feel like the bottle is pretty empty after doing 8 cups.
Old Jan 8, 2021 | 06:12 PM
One Sock's Avatar
One Sock
Wow, that one from Riffraff is expensive. I guess I'll get 2 of the little ones. BTW, I found on Rock you can get a 1.22 ounce bottle of the Permatex stuff, #64040, for $18. But I don't think I need that much.
Old Jan 8, 2021 | 06:59 PM
duck fan's Avatar
duck fan
Because racetruck
Permatex is not what you want. It isn’t the quality needed for doing cups, loctite is superior.
Old Jan 8, 2021 | 07:34 PM
One Sock's Avatar
One Sock
Got supporting evidence? The Permatex appears to have much higher temperature resistance.
https://www.permatex.com/wp-content/.../tds/64000.pdf
https://www.henkel-adhesives.com/us/...ctite_620.html
Old Jan 8, 2021 | 10:38 PM
duck fan's Avatar
duck fan
Because racetruck
Mainly personal experience as I have had to replace cups installed with Permatex in the past. Temp is the same, 200ºC for Loctite and 400ºF for Permatex. Gap fill is better with Loctite. Once main indicator is that you will only find Permatex at places like Oreillys and Napa for general auto use as it is cheap and generic use. Loctite is found in professional applications like hydraulic stores, aviation, machining as well as what the Ford Manual calls for on this application.
Old Jan 9, 2021 | 08:26 AM
Listor's Avatar
Listor
Agree with you on this, You never ever want to do it again, SO buy once Cry once!
Old Jan 9, 2021 | 08:27 AM
Listor's Avatar
Listor
It may be expensive, but Riff Raff is not going to sell you junk! you never want to do this again!
Old Jan 11, 2021 | 05:49 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Less expensive than doing it twice! We only sell Loctite 620 to our customers installing cups. We also only recommend Clay's install/removal tool. We talk to many customers who buy the cheap junk on eBay and have to do the job again.
Old Jan 11, 2021 | 11:21 PM
BWST's Avatar
BWST
Got Data?
I've used Clay's excellent tool set, and loctite 620, and ended up doing the job 7 times (once all 8 cups, then chasing down leakers). The last two of those times were with the help of friends Woodnthings and Tugly.
The two big mistakes I made: Not cleaning the holes adequately so the loctite could bond well, and not pressure testing properly when I discovered the 1st attempt was not successful. I was not able to identify all of the leakers at once. It helps to have no antifreeze in the block to check your work. Easier to see air bubbles around a leaking cup sprayed with silicone, than to see weeping antifreeze on the cup edge.
Old Jan 12, 2021 | 09:03 AM
Listor's Avatar
Listor
Omg That sound like a nightmare!
Tugly
62
May 1, 2023 08:42 PM
uglypitbull
Sep 30, 2020 09:10 PM
JT250
Sep 11, 2012 01:42 PM
nghtrgr
Dec 15, 2008 09:45 AM
pskelton
Jul 28, 2008 05:31 PM
