Copper Injector Washers
Old Dec 14, 2008 | 02:33 PM
nghtrgr's Avatar
nghtrgr
Which way do you put these washers???? Does the side with 2 "raised" portions go toward the injector or does the side with 1 "raised" portion go toward the injector. Thanks
<!-- / message --><!-- sig -->
Old Dec 14, 2008 | 02:50 PM
brickie's Avatar
brickie
The washer goes on with the 1 raised side down.If it was an upright bowl the tip goes into the bowl.
Old Dec 14, 2008 | 02:53 PM
nghtrgr's Avatar
nghtrgr
Just to confirm the side with 1 raised side will touch the injector cup and the side with 2 raised sides will touch the injector.
Old Dec 14, 2008 | 02:55 PM
brickie's Avatar
brickie
Yes thats correct.
Old Dec 14, 2008 | 03:13 PM
nghtrgr's Avatar
nghtrgr
Got it. Thanks.
Old Dec 14, 2008 | 06:32 PM
nghtrgr's Avatar
nghtrgr
Brickie, A guy from other forums say that the side with 2 raised circles goes against the injector and the side with 1 raised circle goes against the injector cup also. Thanks for the help
Old Dec 14, 2008 | 06:49 PM
brickie's Avatar
brickie
Your welcome.I asked the same question to a local tech when I was doing mine.
Old Dec 14, 2008 | 09:12 PM
catalinagoose's Avatar
catalinagoose
Honestly, I don't think it really matters much which way the washer goes. It gets crushed pretty flat when you tighten down the injector hold down anyway.
Old Dec 14, 2008 | 10:34 PM
brickie's Avatar
brickie
I looked at them saw a top and bottom that were both different so asked witch side is up.I will take his word for it and all ways do it that way in the future.I haven't had a problem with mine so I won't change how I was told to do it.
Old Dec 15, 2008 | 09:45 AM
w_huisman's Avatar
w_huisman
Just to make this perfectly clear, can one of you post pictures of these washers?
I was confused by this as well last weekend, but ended up figuring it out with a phone call.
ddeflyer
Feb 19, 2015 12:39 PM
cabloom300
Nov 10, 2013 06:26 PM
nookiemonster55
Oct 22, 2010 01:12 AM
someday
General Automotive Discussion
Sep 19, 2010 09:09 PM
landryd
1983 - 2012 Ranger & B-Series
Aug 23, 2004 07:49 PM
