Sponsored by: Auxito
Check engine light P0302 code
Old Oct 25, 2003 | 10:53 AM
fejetmech's Avatar
fejetmech
Bought a 2001 F-150 super crew with the 5.4 and the day after I bought it it popped a code. My code scanner says its P0302 and my search on the web indicates misfire on the the #2 cyl. Where can I find a complete list of codes for this truck ?
Old Oct 25, 2003 | 02:16 PM
Racerguy's Avatar
Racerguy
These might not all apply to your truck but most will....
http://members.monarch.net/dave_r/dtc's.htm
Old Oct 25, 2003 | 02:39 PM
jerbro57's Avatar
jerbro57
I experienced a similar error code on my ‘01/4.6 (62K miles). Turned out to be the COP (coil-on-plug). The way I tested it was to swap adjacent COP’s and see if the error follows the change. A really easy swap, maybe 10-15 minutes at the most. (be sure to release the connector lock located on the bottom of the plug.) Symptoms are excessive hesitation under light acceleration. After I swapped the coils it took several miles for the “check engine soon” light to re-appear, even with the symptoms still present. A good friend of mine has the same truck, same engine but fewer miles (45K miles) and has had two COP’s fail on him.
Old Oct 25, 2003 | 08:16 PM
Racerguy's Avatar
Racerguy
Hi jerbro57 and welcome to the forum
Thanks for the good advice. Usually if the miss isnt caused by the spark plug it is caused by the COP and swapping with a known good one is an easy way to tell.
Old Oct 26, 2003 | 12:31 AM
LxMan1's Avatar
LxMan1
I tried that link, Dave, and it didn't work.
Jimmy
Old Oct 26, 2003 | 01:55 AM
Racerguy's Avatar
Racerguy
Ok try it again...it should work now.
Thanks for letting me know.
Old Oct 26, 2003 | 01:05 AM
LxMan1's Avatar
LxMan1
AHHH, much better now. Thanks
Jimmy
Oh, quick question Dave, I was looking at my gallery earlier, and all of the titles say hidden by Admin-
What's up with that?
Jimmy
Old Oct 26, 2003 | 11:06 AM
Racerguy's Avatar
Racerguy
I'm not totally sure how that all works. If you take a look in the feedback forum which is closer to the bottom of the main forum page I think you'll find some answers there.
Old Oct 26, 2003 | 11:22 AM
LxMan1's Avatar
LxMan1
Thanks, I under stand the hidden thing now.
Jimmy
superkaz
Modular V10 (6.8l)
Sep 27, 2016 06:06 PM
mooner
1997 - 2003 F150
Sep 13, 2011 09:24 PM
gtmustang00
Jun 15, 2011 11:56 AM
soto8704
2004 - 2008 F150
Sep 28, 2010 10:21 PM
Magicman97
1997 - 2003 F150
Dec 4, 2007 10:28 AM
