Sponsored by: Auxito
P0302
Old Sep 12, 2011 | 06:28 PM
mooner's Avatar
mooner
P0302
1998 F150 with 4.2 L engine. Trips a P0302 code when under load, will not do it idling or just reving. I have changed the coil [ack, plugs and wires. Any other ideas, the truck shakes bad and runs like ****.
Thanks
Old Sep 12, 2011 | 09:55 PM
Bluegrass 7's Avatar
Bluegrass 7
Only thing left is cylinder 2 injector.
Check and seat the connector first, if still an issue consider swapping an injector position.
Good luck.
Old Sep 12, 2011 | 11:57 PM
EZFEED's Avatar
EZFEED
IMRC or IAC
Old Sep 13, 2011 | 12:22 AM
mooner's Avatar
mooner
Thanks for the ideas, found the problem, new plug wire no good had a break in it. Metered wires and it was no good. Whats the odds same plug as origional problem.
New wire and runs great
Old Sep 13, 2011 | 09:24 PM
Bluegrass 7
Good deal. You had the forsite to check new parts.
Saw this happen a number of times over the years.
The wires have carbon filiment cores and can break with a sharp bend.
They normally have a measureable resistance to help with radio noise etc.
A check on AM radio often shows it up as a shot noise everytime the cylinder is sparked.
Good luck.
2003bigred
1997 - 2003 F150
Jul 20, 2018 06:44 AM
DCrusher
1997 - 2003 F150
16
Jan 13, 2014 07:46 PM
73effie
1983 - 2012 Ranger & B-Series
Aug 16, 2009 12:27 AM
AllAcess92
1997 - 2003 F150
27
Dec 30, 2007 09:19 PM
02f250fx4
Modular V8 (4.6L, 5.4L)
Aug 21, 2007 04:06 PM
