Fuel system question
Old Jan 3, 2021 | 01:23 PM
smle's Avatar
smle
Is it a wise to run a mechanical fuel pump and an electric fuel pump together? Or is it better to run one or the other?
Old Jan 3, 2021 | 02:32 PM
65f100_352's Avatar
65f100_352
Generally, people run one or the other.. if I may ask, why do you want to run both?
Old Jan 3, 2021 | 02:36 PM
smle's Avatar
smle
I seem to lose fuel in my lines. Which is causing longer crank times. And I'm not sure I want to run both, which is the reason for the question. I have everything to do it either way.
Old Jan 3, 2021 | 02:47 PM
440 sixpack's Avatar
440 sixpack
Probably a carburator issue. your carb should hold enough fuel to start the engine .
Your mechanical pump should hold the fuel in the lines as well. it may be faulty. electric pumps are a solution looking for a problem on carburated vehicles.
Old Jan 3, 2021 | 03:13 PM
smle's Avatar
smle
It usually does it when it sits overnite. Starting first thing in morning is the hardest, after that no real problems. On third fuel pump now. They will work real good for a few months then get start going down hill.
Old Jan 3, 2021 | 03:50 PM
440 sixpack
The new pumps aren't what they used to be but I've had good luck with the Carter's I've used .
It should take a month to dry down. if you don't have the carb spacer the heat will boil some out and that doesn't help. just one more reason to block the crossover off. but even at that your carb is not holding fuel properly.
On a Holley it's usually a leaking accelerator pump or bad gasket. on Edelbrock I've found this problem to be VERY common even on new carbs and I CANNOT figure out why it happens but it does. as if there was a need for another reason to buy Holley this is it.
Old Jan 3, 2021 | 04:02 PM
smle's Avatar
smle
The fuel pump on it now is a carter and the carb is a holley. Haven't seen any leaking on the carb.
What started all this. The radiator was pulled to be repaired and while it was out I decided to catch up on some stuff. And this is one of those things.
Old Jan 3, 2021 | 05:02 PM
440 sixpack
You should see or at least smell it. but either way if the carb is holding a full float bowl it doesn't need any gas from the pump to start. this is your problem not the pump.
well, or ignition if it's not the carb.
Old Jan 3, 2021 | 05:40 PM
smle's Avatar
smle
You're right on that point. Let me ask you this. This carb is set to be a direct replacement and has all the stuff for the egr. My truck, 78 F150 460, did not come with any of that. The fuel bowl vent that would go to the egr canister is not capped off. Should it be? Could that be part of my problem?
Old Jan 3, 2021 | 05:47 PM
440 sixpack
Possible, the only experience I have with EGR is throwing it away so I can't say for sure. but anywhere gas could leak or evaporate could do it.
Old Jan 3, 2021 | 05:53 PM
smle's Avatar
smle
When I get my radiator back I'll try and cap it and see what happens. Thank you.
Byram
6.7L Power Stroke Diesel
Aug 27, 2013 10:05 PM
6.7L
Feb 3, 2012 09:27 PM
tealboy1
Dec 21, 2008 09:50 AM
breisr
Dec 4, 2008 09:55 AM
Farmboypowerstroke
40
Sep 21, 2008 07:46 PM
