Crank but won't start
2010 Van e350 5.4 with 55k original miles won't start.
I finished installing my trailer hitch, went to drive it back in the garage and engine cranked then battery died. I must have left the doors open with the interior lights on.
Charged battery to 13.5v and went to start it, cranked but engine didn't start. Noticed that the starter still cranking when I released the ignition key and had to turn it back to off position. Tried several time and same thing, no start and key had to be turn back to off position for starter to disengage. I checked all fuses under the hood which were all good.
I'm stumped.
I'm stumped.
The following users liked this post:
Your key sticking in the "start" position is internal to the steering column where the key lock cylinder is housed. Might need cleaned in slightly lubricated or the entire cylinder replaced.
Its fine following that YouTube advice how to check the FPDM but I'd first start by simply checking for fuel pressure on the rails at the test port. If there's no pressure there when the key is first turned to "run" and especially if FP doesn't begin to rise as you're cranking it then its time to move towards the FPDM and/or fuel pump itself.
Hope this doesn't turn into something expensive or tough to fix.
Key isn't sticking, it returns but the starter still cranks until the key is put back in the off position. I found this post that's the same thing what my starter is doing.
"5.4 flexfuel. I was doing more reading, and it seems the starter remaining engaged for a period of time is a "feature" of Fords.".
Can anybody confirm if that statement is correct?
I agree that it makes no sense. Someone must have experience my starter issue that's why I'm asking. I didn't get a chance to check the FPDM yesterday but hopefully in the next day or two.
Got the van back from the shop and was told that the wiring I cut thinking it was for the trailer 7 pin trailer was actually the fuel pump module...DUH.
At any event they soldered and heat shrink the wires back together and I'm good to go. They didn't mention anything about the starter issue.
BTW this is the first Ford I've ever owned and there certainly a learning curve to be had.
RS22b
03-14-2014 04:33 PM
pararescue14
02-08-2012 04:50 PM
sean23johnson
03-13-2007 09:50 PM
