MAF conversion not working
I did a mass air conversion on my 92 ford f150. I have the 95 A9L puter from a stang. It skips and shakes real bad when it shifts to high gear. no power at all. Do I need to get a 94 puter or does it have the same firing order as teh 95. Mine has a firiing order of 15426378. I am trying to find a 94 mass air flow truck eec. F4TF-12A650-AAA is the number. I know that a 95 on up has the HO firing order of 13726548. It runs like it is hitting on 3 cylinders. I did the injector harness changing to sEFI also. Help me fix this problem!!!
Easiest thing to do is to source out an AOD MAF computer as they work on both AOD and 5 speeds.
Did you make a MAF kit or order the FMS one?
Hit Man, I'm guessing his MAF is home brewed, cuz neither mine (5 spd) nor your kit (AOD) was the A9L/P comps.
Luke
Can you hear or feel all of your injectors ticking as they fire?
How long has it been since this truck ran correctly, are there other problems?
Please post your findings as you go, this will be interesting and may save others much time in the future.
What trans do ya have? If you have the AOD, than go with what Hit Man said. If ya have the E4OD, than you'll be more wanting to look for a computer out of a stock MAF equipped 5.0L truck with the E4OD. That'll be your only solution that I can think of right now. The E4OD is computer controlled, and needs the right comp for it.
Luke
Mine came with the C3W1 which is a varation of the A3M1 AOD computers from Mustangs...
Eric
I have the E40D trans. It shakes when it hits high gear. The injectors are hitting correctly they are all firing like the should. The only reason i used the A9L puter is from a post that i got on here a long time ago from a guy that did a maf conversion. I got the MAF meter off a grand marquis, the tubes came new from Ford and the Injector harness was made by a guy at Ford with the EEC connectors to be inserted into the correct pins on the EEC connector.
Are the injectors you are using the same as the MAF is calibrated to? If you have larger injectors the stock Grand Marquise MAF won't work. I used a '94 351W MAF on my '88 truck.
How's the idle?
part# F4PZ-12A650-AA and the engineering #'s could be F4TF-12A650-AAA or
AAB. I know that when I unplug the MAF nothing changes on the way it idles. The idle is fine with the hit of the cam. when you put in gear and drive is when you can tell it is hitting on 3 or 4 cylinders.
The last time it ran right was before I put in the Lunati cam. That is why I had to convert to MAF. It ran ok with the A9L puter in it before I changed the injectors to the SEFI. That is when the problem started.
What are the specs of the cam? Intake/Exhaust dur, int/exh dur, and LSA.
Are you 100% sure you have an E4OD...b/c I am pretty sure as it is computer controller shifts it will not work with out the computer. The E4OD has 20 pan bolts and is a big rectangle with a notch out of the pan. The AOD has 17 I think.
Okay...was your truck Bank-To-Bank injection before you changed stuff up? Was the firing order the 1-5-4-2-6-3-7-8 with the stock cam?
The cam was a Lunati 284/488 cam. LSA i think is 110.
Yes I am 100% sure it is E4OD tranny. Had it rebuilt in January of this year by a tranny shop. The A9l puter was suggested cause it is for a manual tranny and should not affect the automatic shifts. It shifts fine it is just that the shaking is from it not hitting correctly witht he firing order.
Yes it was Bank-to-Bank injection prior to conversion. The firing order is 1-5-4-2-6-3-7-8 with the stock cam and new cam.
This may be dumb but...have you changed your firing order to a HO/351W one of the 1-3-7-2-6-5-4-8 yet?
That cam isn't going to be too friendly to the EEC-IV even with the MAF. The narrow 110LSA is 2* too small for the computer to like. It will run fine after getting it tuned but it will still be quirky with idle sugre sometimes and stuff of that nature.
Hrm...does the E4OD use an independent computer of the EEC-IV to control shifts like the Allison 1000 in the new GM trucks?
No independent puter. Yes I moved the wires to the 1-3-7-2-6-5-4-8 order and no good. My mechanic said will have to change distributers to use that order. Surged up and down before i changed to maf.
You don't have to change distributors to change the firing order...all you have to do is to move the spark plug wires.
You sure the harness was built correctly?
