MAF conversion not working
Old Feb 25, 2006 | 02:30 PM
  #61
termyt00's Avatar
termyt00
92' F150 5.0 has a 15426378 (same as 460 EFI) firing order, the A9L is a 13726548 firing order... you need too change the cam! rewiring will not work, the R/ L O2 sensors need to be aligned with the correct bank of injectors. OR, you can cheat and wire the 2 inputs on the MA computer to the One O2 sensor on the truck...[I have not verified this action] Also the A9L/A9P have no computer controls for the E4OD! it will not work ALONE!!!
Old Feb 25, 2006 | 11:20 PM
  #62
EPNCSU2006's Avatar
EPNCSU2006
If the 94 mustang computer is an automatic computer, it will control the transmission. I thought this issue was resolved two years ago.
Old Feb 25, 2006 | 11:35 PM
  #63
termyt00's Avatar
termyt00
just slapped it up there for future reference...The '94/'95 will control a AODE/4R70W/4R75W, it is missing 1 thing for the E40D/4R100...[Coast Clutch]
I've gone down that Ave. in my quest for the Mass Air conversion.
Old Feb 26, 2006 | 01:08 AM
  #64
88F-150pimp's Avatar
88F-150pimp
Ford put EEC-V computers in '94-up mustangs. That's gotta be your problem, as the pins are probably very different from your original EEC-lV MAP/ E4OD setup. You may be able to find a discontinued Lightning MAF conversion computer on eBay or something. That would work with the 5.8/5.0 HO firing order, give you SFI, and control the E4OD. If not, I'd get an 89-93 computer from a 5.0 mustang that had a T-5 tranny, and then purchase an independent transmission controller for the E4OD.
Old Feb 26, 2006 | 02:27 AM
  #65
Galizien's Avatar
Galizien
As well go over all your connections while you have it apart, never know if the ford guy screwed up a solder connection or broke a contact.
Old Feb 26, 2006 | 10:06 AM
  #66
termyt00's Avatar
termyt00
EECv did not appear in the stang till 1996! '94& '95 were all EECiv w/ETC for the AODE; the Crown Vics /Grand Marquis started EECv in '95 as well as some of the the I-6 Ford trucks .
Old Feb 26, 2006 | 01:24 PM
  #67
88F-150pimp
No. Ford began using EEC-V v1.0 in 1994 in the Mustang. The federal laws requiring a universal diagnostic system went into effect in 1994, but didn't require that all vehicles have this system until the 1996 model year. Ford started with the mustang in 1994, and maybe some other california vehicles or something throughout 94 and 95, but the entire vehicle line didn't go to EEC-V until 1996. Check out this EEC history.
Old Feb 26, 2006 | 01:46 PM
  #68
termyt00's Avatar
termyt00
it must have been a Calif thing , out here it didn't start till '96
Old Feb 26, 2006 | 07:26 PM
  #69
Blurry94's Avatar
Blurry94
GUYS...this thread is from 2003!
Old Feb 26, 2006 | 08:53 PM
  #70
termyt00's Avatar
termyt00
-and its still here...
Old Feb 26, 2006 | 09:56 PM
  #71
Galizien's Avatar
Galizien
lol because YOU brought it back and nobody else noticed the dates
Old Feb 27, 2006 | 12:14 AM
  #72
termyt00's Avatar
termyt00
ell, neither did eye , till after i made the post.... plus i got the ''haven't posted in a while'' nasty gram! so i figure this be a good place to start...
Old Feb 27, 2006 | 10:27 AM
  #73
EPNCSU2006's Avatar
EPNCSU2006
The V6 mustangs had EEC-V in 94, but the 5.0's still used EEC-IV computers.
Old Feb 27, 2006 | 12:04 PM
  #74
termyt00's Avatar
termyt00
that is plausible, i just know the 94-95 v8 were EEC-IV
fordsvt
Mar 15, 2023 10:19 AM
Red454sedgwick
Apr 17, 2016 09:46 PM
93f1505.0L
May 18, 2006 09:22 AM
SVTCobra306
Computer Chips & Tuners
Jul 18, 2005 04:30 PM
monsters
17
Apr 15, 2005 08:30 AM
