Sponsored by: Real Truck
2014 DPF System
Old Dec 26, 2020 | 11:17 AM
hd883chopper's Avatar
hd883chopper
2014 DPF System
Hey everyone, we have a 2014 race truck (2014 F350 6.7L) that we're tinkering with. If the DP filter is removed and replaced with straight pipe, is it necessary to remove the EGR cooler/valve and all that? Or can you just remove the DP filter and stick a tuner on it to prevent the error codes on the dash?
Thx,
hd
Old Dec 26, 2020 | 12:19 PM
Just Strokin's Avatar
Just Strokin
It is not as simple as you are saying. One reason, the tune writers are gone or underground now. You would need someone to code the tune to take care of the issues you described. You might want to via the 6.7 forum and search there for answers.
6.7L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Dec 28, 2020 | 10:32 AM
hd883chopper
Thanks for the tip. I figured it wouldn't be that easy. I guess I was under the impression that by installing on a tuner, it would eliminate the warning messages. Ok, I'll check out the other forum. Thx!
OPCJeff
Feb 8, 2022 05:48 AM
rjlabonte
6.4L Power Stroke Diesel
Mar 17, 2014 10:09 AM
Enomra
Jun 4, 2012 09:21 AM
canucklehead2004
Jun 7, 2010 05:49 PM
dkf
Modular V10 (6.8l)
Aug 3, 2009 08:51 AM
