Valve covers
Old Dec 24, 2020 | 09:38 PM
Brannon Sanford's Avatar
Brannon Sanford
Valve covers
I'm wanting these scott drake valve covers 351 polished but for some reason says they will not fit efi models any particular reason why? I happen to know my heads were swapped with 302 heads im wondering if its because of the height clearance or what
Old Dec 24, 2020 | 11:07 PM
wwhite's Avatar
wwhite
Depends on what you have EFI or carburettor setup, and intakes.
Carburettor valve covers could be taller, and height could be a clearance issue, depending on the intake.
I think the Scott Drake 351 valve covers were meant for carburettor setup.
Old Dec 25, 2020 | 09:51 AM
Brannon Sanford
yes I was trying to see what my options were i have a buddy with a 96 f150 with the 302 and has the same valve covers but the say they won't work for efi but his is and they work fine
Old Dec 25, 2020 | 10:28 AM
SFaulken's Avatar
SFaulken
The truck EFI Intake Plenum will probably fit just fine. It's the Lower car "cobra" plenums that probably cause the issues, they fit pretty tight down over the top of the valve covers. Just a guess on my part. Alot of the SBF dressup parts are aimed at the 5.0 Mustang crowd, they're not really thinking of the Truck guys.
Old Dec 25, 2020 | 10:55 AM
Brannon Sanford
Im going to try a set cause my buddy has them on his 96 5.0 and they are fine so I think the 351 covers will work on my 95 5.8
Old Dec 25, 2020 | 11:03 AM
TrixR4kids's Avatar
TrixR4kids
Well Please post back once you find out for sure. I was looking at those and couldn't bring myself to pull the trigger because of the EFI statement.
Old Dec 25, 2020 | 01:40 PM
Brannon Sanford
yes i sure will least can happen is they don't fit and I can return them
Old Dec 25, 2020 | 02:17 PM
GoinBoarding's Avatar
GoinBoarding
Best I can recall the 5.0 and 5.8L truck upper plenums clear the valve covers the same. So if they worked on your friends 5.0L you're set.
And just a note, the 5.0L and 5.8L EFI truck engines had nearly identical heads from Ford. The only difference being that the 5.8L heads were drilled for 1/2" head bolts where the 5.0L was drilled for 7/16" bolts. Same castings (E7).
Old Dec 25, 2020 | 02:22 PM
Brannon Sanford
Gotcha I appreciate the info fellas have a merry Christmas
Old Dec 26, 2020 | 09:33 PM
jackietreehorn's Avatar
jackietreehorn
It has to do with the oil filler neck and PCV grommet. I don’t think carb/car valve covers are compatible.
Old Dec 27, 2020 | 01:24 AM
Scndsin's Avatar
Scndsin
Carb VCs put oil fill front passenger side, PCV grommet front driver's side.
Very few OBS EFI truck specific valve covers & these are getting fewer & more expensive:
Old Dec 27, 2020 | 08:45 AM
timbersteel's Avatar
timbersteel
OH!! THOSE ARE PRETTY!!!!
Old Dec 27, 2020 | 09:31 AM
Scndsin's Avatar
Scndsin
They are nice. With a fel-pro metal core/silicon gasket & good fasteners they are leak proof with multiple removal/installations.
After 4-5 years, they are getting a bit of "white on the bare portions. Like to get some shark-hide, but a bit of oil wiped on keeps it in check.
Old Jul 5, 2025 | 04:55 PM
Nmaykdm's Avatar
Nmaykdm
did these Scott drake valve covers work out for you?
Acameron19
Engine Swaps
Sep 2, 2013 07:56 PM
crazy96863
Aug 24, 2013 02:36 AM
dgriffinhere
1978 - 1996 Big Bronco
Apr 11, 2013 12:40 PM
JCastellaw
1966 - 1977 Early Broncos
Dec 4, 2007 03:30 PM
