67 rear axle width ??
Old Dec 24, 2020 | 05:58 AM
Renner68's Avatar
Renner68
I recently bought a 67 f100 swb 2wd for my wife 50th B-day. I familiar with dent sides but bumps not so much. Is it correct for the rear track to be narrower than front by 3'' or so ? My main question is if that's correct is i have a spare rear from a 73. Do people swap them , and move spring perch on axles to achieve a better look?
Old Dec 24, 2020 | 08:14 AM
john jamieson's Avatar
john jamieson
I believe up to '72 was narrower than '73 onward by 4". It can cause tire clearance issues with slicks but I'm not sure with bumps
Old Dec 24, 2020 | 10:42 AM
GPatrick's Avatar
GPatrick
I put a wider rear under my 70 F-250 and have no clearance issues. I was told or read that the narrower rear helped make the turning radius a little smaller but I didn't care for the look of it myself. If you make the change, pull your existing rear axle out and match the perch to pinion angle exactly and you should be good to go. These are the perches I used for the 2-1/4" springs - https://www.ruffstuffspecialties.com/R1991.html
Old Dec 24, 2020 | 01:36 PM
Renner68's Avatar
Renner68
thanks much appreciated, especially look's bad totally stock. As my wife likes the stock look but did notice that which i was surprised.
jrockdiddy
May 22, 2013 12:36 AM
Perschml
Dec 16, 2010 06:26 PM
likethefords
Dec 25, 2007 08:04 AM
goodolboy
Jul 14, 2005 08:45 PM
BB
Apr 11, 2002 01:49 PM
